This calculator allows you to convert pressure values from bar to millimeters of water column (mmWC), which is useful in various instrumentation and process control applications.
Definition: Bar
A bar is a metric unit of pressure, defined as 100,000 Pascals. It is not an SI unit, but it is widely used in various industries, especially in meteorology and engineering.
Definition: Millimeter of Water Column (mmWC)
A millimeter of water column (symbol: mmWC or mmH₂O) is a unit of pressure that represents the pressure exerted by a 1 mm high column of water at 4°C under standard gravity. It is commonly used in HVAC systems, gas pressure measurements, and low-pressure systems.
Formula for Bar to mmWC Conversion:
Pressure in mmWC=Pressure in Bar×10197.16
How to Convert Bar to mmWC: Example Calculation
Suppose you have a pressure of 1 bar.
To convert it to millimeters of water column (mmWC):
1 bar×10197.16=10197.16 mmWC
So, 1 bar is equal to 10197.16 mmWC.
Quick Reference Conversion Table for Bar to mmWC
Bar | Millimeter of Water Column (mmWC) |
0.1 bar | 1019.72 mmWC |
0.5 bar | 5098.58 mmWC |
1 bar | 10197.16 mmWC |
2 bar | 20394.32 mmWC |
5 bar | 50985.8 mmWC |
10 bar | 101971.6 mmWC |
Use of Bar to mmWC Conversion Calculator:
- HVAC Systems: Convert pressure readings for ventilation and air-conditioning systems where mmWC is often used.
- Process Instrumentation: Use in low-pressure system conversions where precise measurement is needed.
- Pneumatics and Hydraulics: Ideal for converting bar measurements into mmWC for control and monitoring in fluid systems.
- Water Treatment Plants: Ensures accuracy in systems where water column pressure measurements are required.
This calculator is a valuable tool for professionals in fields like engineering, process control, and instrumentation that require accurate pressure conversions.
Common Pressure Conversions with Millimeter of Water Column (mmWC)
Below are the most frequently used conversion calculators and formulas involving mmWC (Millimeters of Water Column), a widely used low-range pressure unit in HVAC, industrial, and laboratory applications.
- Millimeter of Water Column (mmWC) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
- Millimeter of Mercury (mmHg) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Kilopascal (kPa) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Kilopascal (kPa) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Millibar Pressure Unit Conversion Calculator
- Millibar to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Kg/cm² to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Kg/cm² Pressure Unit Conversion Calculator
- Psi to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Psi Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Bar Pressure Unit Conversion Calculator
- Bar to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
Frequently Asked Questions
Is 1 mmWC equal to a bar?
No, 1 mmWC = 9.80665 × 10⁻⁵ bar.
To put it in context:
- 1 bar = 10,197.162 mmWC (at standard gravity and 4°C water density)
- 1 mmWC = 0.0014 psi
- 1 mmWC = 9.80665 Pascal (Pa)
What is the formula for converting bar to mmWC?
To convert pressure from bar to mmWC:
This is based on:
- Standard gravity: 9.80665 m/s²
- Water density at 4°C: 1000 kg/m³
How many mmWC are there in 1 kg/cm²?
1 kg/cm² = 10,000 mmWC
This is a common conversion used in hydraulic and pneumatic systems.
What is the unit mmWC used for?
mmWC (Millimeters of Water Column) is a low-range pressure unit derived from the hydrostatic pressure exerted by a 1 mm high water column at 4°C.
- Often used in HVAC, cleanrooms, and differential pressure measurements.
How to convert mmWC to Pascals (Pa)?
Use the standard conversion factor:
1 mmWC = 9.80665 Pa
To convert, multiply mmWC by 9.80665.
Example: 50 mmWC = 50 × 9.80665 = 490.33 Pa
