Table of Contents
- Applications of SCADA
- What is SCADA?
- Applications of SCADA include
- 1. Electricity Generation, Transmssion, and Distribution Systems:
- 2. Manufacturing Industries or Plants:
- 3. Food & Pharma Production:
- 4. Telecom & IT-based systems:
- 5. Water Treatment Plants, Sewage Treatment Plants, & Supply Management:
- 6. Traffic Controls:
- 7. Lift & Elevator Controls:
- 8. Buildings & Society Environments:
- 9. Oil & Gas Systems:
- 10. Mass Transit & Railway Traction:
- SCADA in Power transmitting Systems
- Some of the applications are
- Benefits of SCADA for Power Systems
- The general features of a SCADA substation system are
- Additional features of the substation control system
- SCADA for Power Utility Network
- Features of Power Network Utilities
- Objectives of SCADA
- The application of SCADA
- SCADA Advantages
- Frequently asked Questions
What is SCADA?
- SCADA stands for Supervisory Control and Data Acquisition.
- SCADA is a computer-based system to analyze real-time production data. SCADA monitors and manages alarms, and programs for automatic responses triggered by system parameters.
- SCADA system is a very essential tool for process automation.
- It helps to be aware of potential network issues.
- It makes informed decisions to respond accordingly on time.
- It is a type of remote monitoring system to manage and control equipment to eliminate human error.
- SCADA is widely used in various sectors such as chemical, gas, water, communications, and power systems.
- SCADA is a combination of software and hardware elements for process industries to
- Process Control & monitor in real-time from a remote location
- Analysis & calculation of complex processes & maintaining control signals accordingly.
- Data Acquisition, Historical Data Logging, Archiving & Retrieving
- Trend & Alarm Generation
- Recipe Management in Process & Chemical Industries
- Report Generation
- SCADA systems are used in electric power generation plants, transmission areas, and distribution systems.
- SCADA systems monitor each and every phase of the generation of electricity from fuel input to electrical output.
- SCADA systems can also be used to monitor and control electrical switchboards, Grids, and transmission lines.
- SCADA monitors and controls the actual electrical power being transmitted over long distances.
- This system responds to load fluctuations instantaneously.
- A SCADA helps in managing various raw materials or inventory items, to control automated systems in synchronous order.
- SCADA precisely controls every plant operation to ensure all systems run smoothly and meet productivity targets.
- SCADA tracks the number of units produced, & measures process values such as temperature, pressure, and humidity at various production phases.
- It also controls assembly line robots.
- SCADA system monitors and controls all stages of the production unit.
- Controls the exact mixture of required ingredients.
- Monitors the time and temperature required to manufacture & process food & beverages or pharmaceutical products.
- SCADA documents data to prove the production meets the industrial standard and government regulations.
Managing different Radio Frequency based systems, communication mediums, and large communication systems such as logging data and information through an antenna using a SCADA system is very easy.
- Municipal Corporations and other government sectors are using SCADA for monitoring, controlling, and regulating the level and flow of water in dams & reservoirs.
- SCADA system monitors and controls the water being pumped from bore wells and treated at WTP.
- This system controls flow rate sensors and contaminant sensors.
- This controls the booster pump to regulate the water pressure supplied to the process.
- In metropolitan cities, SCADA regulates traffic signal lamps, detects signals out-of-order, & controls traffic flow.
- In railway systems, on-road systems, & airlines the traffic flow is controlled by the SCADA system.
SCADA system can also be used to lift and control elevators in commercial malls and in large industries.
Facility managers use SCADA to control High Voltage AC, refrigeration units, lighting, and entry systems.
- SCADA system monitors wells and pumping sites, pumping pressure, pipeline flow, and compressor stations.
- It detects irregularities to prevent catastrophic events from occurring for safety.
- Transport authorities use the SCADA system to
- Control supply of electricity to subways, trams, and trolley buses.
- To automate traffic signal indication for railways.
- To track and locate trains and buses.
- To control railway crossings.
- SCADA protocols also regulate electricity in remote locations.
- Re-routing services for station maintenance
- Service Restoration
- Protective relay interface/interaction
- Voltage regulation management
- Load tap changer control
- Transformer management
- Real-time modeling.
- Automatic control of circuit isolation.
- collective switch control display
- Interface real-time single-line displays
- On-line operation and maintenance logs
- Automatic system diagnostics through system alarm management.
- Comprehensive operational planning and control
- Fuel resource scheduling
- Optimum power flow
- Network security
- Economic dispatch
- Generation dispatch control
- Improved quality of service
- Improved reliability
- Reduced operating costs
- Maintenance /Expansion of customer base
- Ability to defer capacity addition projects
- High-value service providers
- Improved information for engineering decision
- value-added services
- Flexible billing option
- Improved customer information access
- Reduced system implementation costs
- Reduced manpower requirements
- Substation parameter monitoring
- Controlling electrical network components remotely
- Safety tagging
- High-resolution time stamping
- The sequence of event reporting for post-event analysis
- Demand side management
- Volt/VAR control
- Preventive maintenance
- Fault detection isolation and restoration.
- Power Utility Network (PUN) software provides an electrical utility with tools to enhance system operation at a very low cost.
- The PNU software consumes real-time SCADA data.
- PNU logic is a combination of both mathematical and logical techniques.
- The present scenario is to produce and distribute quality power at the minimum investment.
- Proper operation of the electrical network & having real-time data about the network helps to achieve the required goal.
- PNU provides the user with a host of applications to distribute automation.
- Component Modeling
- State Estimation
- Bad Data Suppression
- Contingency Analysis
- Fault Isolation/Islanding
- Load Shedding
- Volt/VAR Scheduling
- Dispatcher Power Flow
- Short Circuit Analysis
- Network Topology Processor
Objectives of SCADA
There are many objectives of the SCADA System.
- Improves overall System efficiency such as capital & energy.
- Increases penetration of energy sources along with renewable energy sources.
- Reduces energy requirements at generation and transmission sections
- Increases sequence to essential loads.
- In power plants, the SCADA serves the invaluable safety and protection
- This system attempts to solve the fault that occurred and restore power quickly when a fault is experienced in a transmission line.
SCADA Advantages
- Receiving real-time information to monitor equipment
- Remote industrial control
- Storage of performance data for later analysis
- It allows for dynamic maintenance and reduces downtime
What are the four types of SCADA?
The SCADA systems are classified into four types
- Monolithic SCADA system,
- Distributed SCADA system,
- Networked SCADA system, and
- I-o-T SCADA system.
What is an example of SCADA?
Basically, SCADA systems control and monitors physical processes. General examples of SCADA are
- Transmission of Electricity,
- Transportation of Gas & Oil in Pipelines,
- Water Distribution,
- Traffic Lights.
What are the four functions of SCADA?
The four primary functions of the SCADA system are:
- Data Acquisition,
- Network Data Communication,
- Data Presentation,
- Data Control.
What language is SCADA?
- Most SCADA systems are now programmed using standard interfaces.
- Basically, C, or a derived programming language is used as a SCADA language.
What is the main function of SCADA?
The basic function of SCADA systems are
- Collects field information,
- Transfer it to the main computer.
- Displays the process information as a graphical representation.
