45 ISO standards for Industrial Pipelines
1. ISO 7-1:1994-05
Pipe threads where pressure-tight joints are made on the threads – Part 1: Dimensions, tolerances and designation
2. ISO 7-2:2000
Pipe threads where the threads are pressure-tight Part 2: Verification by means of limit gauges
3. ISO 49:1994
Malleable cast iron fittings threaded to ISO 7-1
4. ISO 228-1:2000
Pipe threads where the threads do not contain pressure-tight joints-Part 1: dimensions, tolerances and designation
5. ISO 228-2:1987
Pipe threads where the threads do not contain pressure-tight joints ; Part 2: verification using limit gages
6. ISO 264:1976
Unplasticized polyvinyl chloride (PVC) fittings for tubes under stress with simple sockets ; layout lengths ; metric series
7. ISO 265-1:1988
Pipes and fittings of plastics materials; fittings for domestic and industrial waste pipes; basic dimensions: metric series; part 1: unplasticized poly(vinyl chloride) (PVC-U)
8. ISO 1179:1981
Pipe connections for flat steel and other metal pipes in industrial applications, threaded to ISO 228/1
9. ISO 1635-2:1987
Seamless wrought copper and copper alloy tube
10. ISO 2016:1981
Capillary solder fittings for copper tubes; Assembly dimensions and tests
11. ISO 2035:1974
Unplasticized polyvinyl chloride (PVC) moulded fittings for elastic sealing ring type joints for use under pressure; Pressure-resistance test
12. ISO 2044:1974
Unplasticized polyvinyl chloride (PVC) injection-moulded solvent-welded socket fittings for use with pressure pipe; Hydraulic internal pressure test
13. ISO 2531:1998
Ductile iron pipes, fittings, accessories and their joints for water or gas applications
14. ISO 2804:1996
Wire, bar or tube drawing dies – As-sintered pellets of hardmetal (carbide) used as wire, bar and tube drawing dies.
15. ISO 2851:1993
Stainless steel bends and tees for the food industry
16. ISO 2852:1993
Stainless steel clamp pipe couplings for the food industry
17. ISO 3183-1:1996
Petroleum and natural gas industries – Steel pipe for pipelines – Technical delivery conditions – Part 1: Pipes of requirement class A
18. ISO 3183-2:1996
Petroleum and natural gas industries – Steel pipe for pipelines – Technical delivery conditions – Part 2: Pipes of requirements class B
19. ISO 3253:1998
Gas welding equipment – Hose connections for equipment for welding, cutting and allied processes.
20. ISO/TR 3313:1998
Fluid flow measurement in closed conduits โ€” Guidelines for the impacts of flow pulsations on flow measuring instruments
21. ISO 3419:1981
Non-alloy and alloy steel butt-welding fittings
22. ISO 3458:1976
Assembled joints between fittings and pressure pipes made of polyethylene (PE) ; leak resistance test under internal pressure
23. ISO 3459:1976
Pressure pipes for polyethylene (PE) ; joints with mechanical fittings ; technique and requirement for internal underpressure testing
24. ISO 3477:1981
Polypropylene (PP) pipes and fittings, for density test applications.
25. ISO 3501:1976
Assembled joints between fittings and polyethylene (PE) pressure pipes; Test of resistance to pull out.
26. ISO 3503:1976
Assembled joints between fittings and polyethylene (PE) pressure pipes; Test of leakproofness under internal pressure when subjected to bending.
27. ISO 3545-3:1989
Steel tubes and fittings ; specification symbols ; part 3: circular cross-section tubular fittings.
28. ISO 3586:1976
Glass plant, pipeline and fittings; general rules for testing, handling and use.
29. ISO 3587:1976
Glass plant, pipeline and fittings ; nominal bore pipeline and fittings of 15 to 150 mm ;
30. ISO 3603:1977
Fittings for pressure pipes with elastic sealing ring type joints for unplasticized polyvinyl chloride (PVC) ;
31. ISO 3604:1976
Fittings for unplasticized polyvinyl chloride (PVC) pressure pipes with elastic sealing ring type joints ; leakage pressure test under internal hydraulic pressure circumstances
32. ISO/TR 5168:1998
Measurement of fluid flow – Evaluation of uncertainties
33. ISO 5730:1992
Stationary shell boilers of welded construction (other than water-tube boilers)
34. ISO 6448:1985
Rubber seals ; joint rings used to supply tubes and fittings for petroleum products ; material specifications
35. ISO 6594:1983
Cast iron drainage pipes and fittings; Spigot series
36. ISO 6605:2002
Hydraulic fluid power – Hoses and hose assemblies – Test methods
37. ISO 7387-1:1983
Adhesives with solvents for assembly of u PVC pipe elements; Characterization; Part 1 : Basic test methods
38. ISO 8434-1, :1994
Metallic tube connections for fluid power and general use –
Part 1: 24 compression fittings
39. ISO 8434-3:1995
Part 3: O-ring face seal fittings
40. ISO 10420:1994
Petroleum and natural gas industries; flexible pipe systems for subsea and marine riser applications
41. ISO 10931-1:1997
Plastics piping systems for industrial applications – Poly(vinylidene fluoride) (PVDF) – Part 1: General
42. ISO 11961:1996
Petroleum and natural gas industries – Steel pipes for use as drill pipe – Specification.
43. ISO 13664:1997
Seamless and welded steel tubes for pressure purposes – Magnetic particle inspection of the tube ends for the detection of laminar imperfections
44. ISO 11496:1993
Seamless and welded steel tubes to detect laminar imperfections ; ultrasonic testing of pipe ends.
45. ISO 11961:1996
About The Author
