Accelerometers are a piezo-electronic (crystal) device. A pre- loaded crystal is charged with current and as the crystal is compressed or de-compressed by vibration an output proportional to g’s (gravity) is provided.
A “g” is equal to 9.80 meters/second2 or one (1) standard earth gravity.
Accelerometers are normally used for high-frequency bearing cap vibration readings (Case/Bearing Cap Absolute on machines using rolling element bearings. Usually the output is integrated electronically to velocity
(in/sec or mm/sec). Other applications include monitoring Gears and High Frequency Applications.
Accelerometert – Operating Principle
The most obvious starting point in the system is the accelerometer itself. It is simply a transducer that converts an applied acceleration to its body into a proportionate displacement of voltage on its output.
Signal Conditioning
The Signal Condition Consist
1,Accelerometer
2.Current Source
3.Grounding
4.AC Coupling
5.Instrumentation Amplifier
6.Low pass filter
7.Simultaneous sample and Hold
The signal conditioning circuitry for measuring vibration is fairly straightforward. It consists of the accelerometer itself, a current source to excite the accelerometer, proper grounding to eliminate noise pick-up, AC coupling to remove DC offsets in the system, an instrumentation amplifier to boost the accelerometer’s signal level, a low pass filter to reduce noise and prevent aliasing in the data acquisition system, and finally, simultaneous sample and hold circuitry to keep the signals properly timed with respect to each other.
