RTD Temperature Coefficient Calculation
What is the coefficient factor of RTD?
RTD Temperature Coefficient Calculation 1
  • Resistance Temperature Detectors (RTDs), also known as platinum resistance thermometers (PRTs), are widely used temperature sensors that rely on the principle that the resistance of a metal, in this case, platinum, increases with temperature.
  • RTDs functions according to the theory that the resistance of a metal will increase as temperatures increase.
  • The Temperature Coefficient of Resistance (TCR), denoted by αo, is a crucial parameter for RTDs.
  • It represents the average resistance change per degree Celsius over a specified temperature range, usually 0°C to 100°C, divided by the resistance of the RTD, Ro, at 0°C.
How is RTD coefficient calculated?
Here’s a step-by-step explanation of how to calculate the TCR for a PT100 RTD, along with an example calculation:
αo = (R100−R0) / (R0 X 100oC)   – Equation no. 1
R0 is the resistance of the RTD at zero degrees Celsius (ohm).
R100 is the resistance (ohm) of the RTD at 100 °C.
Note: For the purpose of this conversation, we will only be referring to RTD PT100.
The relationship between resistance (Rt) and temperature (t) for a PT100 RTD is described by the following formula:
Rt= R0(1+αo.t)   – Equation no. 2
Where:
Rt  is the RTD‘s output resistance in Ohms at temperature t.
R0 is the resistance of the RTD at 0°C (ohms).
αo is the temperature coefficient of resistance (TCR) at 0°C (per °C).
t is the temperature in degrees Celsius.
Example Calculation
Platinum RTD PT100 has a resistance of 100 ohms at 0 degrees Celsius and 139.1 ohms at 100 degrees Celsius.
  1. Find out how much resistance the RTD has at a temperature of 60 degrees Celsius.
  2. Perform the TCR (Temperature Coefficient of Resistance) calculation for platinum.
  3. Determine the temperature at which the resistance is 120 degrees Celsius.
What is temperature coefficient of Pt100?
Perform the Temperature Coefficient Calculation on the RTD PT100.
From Equation no.1:
αo = (139.1 -100) / (100 X 100)
αo = 0.00391 per degrees Celsius
Determine the RTD’s resistance at 60°C
From Equation no.2:
Rt= R0(1+αo.t)
R60 = Ro(1 + αt)
R60 = 100(1 + 0.00391×60)
R60 = 123.46Ω
From Equation no.2 :
R120 = Ro(1 + αt)
120 = 100(1 + 0.00391t)
1 + 0.00391t =120/100
0.00391t = 1.2-1
t = 0.2/0.00392
t = 51.02 degrees Celsius
