PSIA to PSIG Conversion Calculator
Accurate pressure measurement is vital in the field of process engineering, instrumentation, and industrial control systems. Knowing multiple pressure units and how to convert between them ensures safe operations, effective designs, and consistent data interpretation. PSIA (Pounds per Square Inch Absolute) and PSIG (Pounds per Square Inch Gauge) are two often used pressure units.
The main distinctions between PSIA and PSIG, the function of atmospheric pressure, and a straightforward formula for correctly converting PSIA to PSIG are all covered in this article. There is also a simple calculator for quick conversions.
Starting from a perfect vacuum, PSIA measures pressure on an absolute scale. PSIA therefore considers all pressure at a place, including the surrounding air pressure.
For instance, a sealed chamber with an internal pressure of 64.7 PSIA would contain 50 PSI of internal pressure from the contents plus 14.7 PSI of atmospheric pressure (at sea level).
  • Relates pressure to a perfect vacuum (zero reference point).
  • Reads including atmospheric pressure in it.
  • Usually applied in thermodynamic, laboratory, and scientific contexts where absolute conditions are required.
  • Necessary for precise computations including gas laws, fluid flow, and altitude compensation.
PSIG gauges pressure in relation to the ambient atmospheric pressure. In most actual industrial uses, this is the most common kind of pressure reading.
A gauge reading of 0 PSIG indicates the pressure is equal to atmospheric. A gauge reading of 50 PSIG indicates the actual pressure inside the system is 50 PSI above the atmospheric pressure.
  • Indicates the disparity between internal and ambient pressure.
  • Excludes from the reading atmospheric pressure.
  • Often found in industrial automation equipment, compressed air systems, water pumps, and HVAC systems.
  • Easier for operators and field engineers to understand in day-to-day activities.
The weight of the Earth’s atmosphere exerts force called atmospheric pressure. It acts on everything at the Earth’s surface and is quite important for our measurement and interpretation of pressure.
The usual atmospheric pressure at sea level is about:
  • 14.7 PSI (pounds per square inch)
  • 101.3 kPa (kilopascals)
  • 1 atm (standard atmosphere)
Pressure conversions depend on this amount, which is added or subtracted depending on the direction of conversion.
The image illustrates the difference between PSIG (Pounds per Square Inch Gauge) and PSIA (Pounds per Square Inch Absolute) using a visual scale. It shows that PSIA includes atmospheric pressure (14.7 PSI at sea level), starting from a perfect vacuum (0 PSIA), while PSIG measures pressure relative to atmospheric pressure. The PSIG scale begins at 0 when atmospheric pressure is present and increases based on applied pressure. The vacuum range exists below atmospheric pressure on the PSIG scale, often shown as negative gauge pressure. A pressure gauge on the right visually represents PSIG readings with both positive and vacuum (inHg) scales.
In order to convert a pressure value from PSIA to PSIG, you must first subtract the standard atmospheric pressure from the measurement of the pressure. A standard pressure gauge shows the pressure above atmospheric, which this conversion offers you by removing the atmosphere component.
Where: At sea level, the average atmospheric pressure is 14.7 pounds per square inch.
To understand how the conversion functions, let’s walk through a practical example.
  • Absolute Pressure (PSIA): 64.7
  • Atmospheric Pressure: 14.7
PSIG=64.7PSIA−14.7PSI=50PSIG
Thus, 50 PSIG is the equivalent to 64.7 PSIA. This shows the internal system pressure is 50 PSI above the ambient air pressure.
You may quickly and precisely convert PSIA to PSIG using the following online calculator:
  1. Enter the PSIA value into the input field (e.g., 64.7).
  2. Click the Calculate button.
  3. The calculator will subtract 14.7 PSI (standard atmospheric pressure).
  4. The output will display the result in PSIG.
Engineers, technicians, and students dealing with pressure systems that require fast, dependable conversions will find this tool very helpful.
Click for PSIG to PSIA Conversion Calculator
Accurate conversion between PSIA and PSIG ensures that:
  • Equipment is not under-utilized or over-pressurized.
  • Safety systems run under their intended pressure limitations.
  • Calculations still exact include those on energy transfers, gas laws, or flow rates.
  • Control systems react properly depending on real pressure data.
Process industry, laboratory, HVAC, and energy sector personnel may keep system correctness, guarantee safety, and increase operational efficiency by knowing and using the appropriate conversion between PSIA and PSIG.
In situations when pressure has to be measured from an actual zero reference, such as a perfect vacuum, PSIA is absolutely crucial. In vacuum distillation, where exact pressure control below atmospheric is required to affect boiling points, this is very important. Aerospace engineering uses PSIA to track cabin and fuel tank pressures in proportion to the low ambient pressure at high altitudes or in space. PSIA guarantees containment under very low or high absolute pressure settings for gas storage and cryogenics applications. Scientific calculations employing gas laws for example, PV=nRT  also call for absolute pressure to properly forecast gas behaviour.
Combining PSIA with PSIG could cause major operational problems. For instance, sizing a safety relief valve using PSIA rather than PSIG could provide an undersized valve, hence generating overpressure and possible equipment failure. Reading a gauge (PSIG) as absolute pressure (PSIA) could confuse maintenance teams during calibration in compressed air systems, hence generating incorrect pressure transmitter configurations.
Increasing height impacts atmospheric pressure, which in turn affects the PSIA to PSIG connection. Standard atmospheric pressure at sea level is 14.7 PSI. At 5,000 feet height, though, atmospheric pressure falls to about 12.2 PSI. Accurate conversions should take this into account:
PSIG = PSIA – Atmospheric Pressure (adjusted for altitude)
Elevation (ft)Atmospheric Pressure (PSI)
0 (Sea level)14.7
1,00014.2
5,00012.2
10,00010.1
  • PSIA Instruments: Altitude sensors, vacuum sensors, barometers, absolute pressure transmitters.
  • PSIG Instruments: Bourdon tube pressure gauges, HVAC gauges, and hydraulic system signals are all examples of gauges.
UnitEquivalent to 1 atm
PSIA14.7 PSI
PSIG0 (when at atmospheric)
Bar1.01325 bar
kPa101.325 kPa
mmHg760 mmHg
inHg29.92 inHg
Click here to find 200+ Online Instrumentation Calculators Collections
