Pascal (Pa) to Psi Conversion Calculator
This below tool helps you convert pressure values from pascals (Pa) to pounds per square inch (psi)
The pascal (symbol: Pa) is a unit of pressure in the International System of Units (SI), defined as one newton per square meter (N/m²).
A pound-force per square inch (symbol: psi) is a unit of pressure in the imperial and US customary systems, defined as the pressure resulting from a force of one pound-force applied over an area of one square inch.
Suppose you have a pressure of 500,000 Pa.
To convert it to psi:
500,000×0.000145038=72.519psi
So, 500,000 Pa is equal to 72.519 psi.
Pascal (Pa)Psi (pound-force per square inch)
1,000 Pa0.145038 psi
5,000 Pa0.72519 psi
10,000 Pa1.45038 psi
50,000 Pa7.2519 psi
100,000 Pa14.5038 psi
500,000 Pa72.519 psi
1,000,000 Pa145.038 psi
  • Engineering Applications: Convert pressures in various systems, including hydraulic and pneumatic systems.
  • Instrumentation: For converting gauge readings from SI units to imperial units.
This calculator is essential for engineers, technicians, and others who require accurate pressure conversions.
