This calculator enables quick and accurate conversion of pressure values from Pascal (Pa) to Millimeter of Water Column (mmWC). It is widely applicable in industrial, scientific, and environmental settings where these units are frequently used.
Definition: Pascal (Pa)
The Pascal (Pa) is the SI unit of pressure and is defined as one Newton per square meter (N/m²). It is the standard unit used globally in scientific research, engineering, and industrial processes.
Definition: Millimeter of Water Column (mmWC)
The Millimeter of Water Column (mmWC) measures pressure as the height of a 1 mm column of water at 4°C under standard gravity. It is commonly used in HVAC systems, water flow measurements, and pressure testing.
Formula for Pa to mmWC Conversion
Pressure in mmWC=Pressure in Pa÷9.80665?
How to Convert Pa to mmWC: Example Calculation
Suppose you have a pressure of 100 Pa. To convert it to mmWC:
Pressure in mmWC=100?Pa÷9.80665=10.19716?mmWC
Thus, 100 Pa is equal to approximately 10.197 mmWC.
Quick Reference Conversion Table for Pa to mmWC
Pascal (Pa) | Millimeter of Water Column (mmWC) |
1 Pa | 0.101972 mmWC |
10 Pa | 1.01972 mmWC |
50 Pa | 5.09858 mmWC |
100 Pa | 10.1972 mmWC |
500 Pa | 50.986 mmWC |
1000 Pa | 101.972 mmWC |
Uses of Pa to mmWC Conversion Calculator
- HVAC Systems: Commonly used for pressure drop and airflow calculations.
- Industrial Calibration: Essential for converting pressure readings for process control.
- Hydraulic Systems: Helps in converting hydraulic pressure values.
- Environmental Studies: Frequently used in water pressure and flow research.
This Pa to mmWC conversion calculator is an essential tool for professionals in fields where precise pressure unit conversions are necessary.
Here you can refer more 200+Online Instrumentation Calculators Collections
