Paddle level switch Working
The paddle type level switch is used for the detection of dust level or litter material in silo, hoppar, etc. The rotating vane is continuously rotated by a motor. When this pallet comes into contact with the material, more force than the rotating torque will be applied to the pallet and rotation will stop. The level switch detects rotation, stops and sends the contact.
Working Principle of Paddle Level Switch
A paddle level switch is a type of level sensor used to detect the presence or absence of bulk materials such as powders or solids (e.g., grains, pellets, or cement) within storage containers like silos or hoppers.
The principle is based on the moment of resistance change of a rotating vane in the air or in a medium. The electric rotation and slow rotation blade (frequency = 1 Hz) is at the level of the selected limit. The ascending product slows the rotation, the hinged transmission system changes its position and triggers a microswitch. As the level drops, the inverter returns to its original position by spring force and the microswitch restarts the motor.
Paddle level switches continuously monitor the rotation of the paddle, allowing for real-time detection of material presence without manual intervention. This automatic feature ensures seamless operation in bulk handling systems.
One of the standout features is the ability to detect faults without needing to disassemble the instrument. This reduces downtime and maintenance costs, a crucial benefit in industries with demanding production schedules, such as manufacturing or agriculture in India.
Paddle level switches are designed for straightforward installation, making them user-friendly. Their plug-and-play nature allows for quick setup in both new installations and replacements, even in remote or industrial areas.
These switches come with durable, weather-resistant plastic housings that protect the internal components from harsh environmental conditions. The transparent cover allows operators to visually inspect the internal workings, an added convenience that improves usability.
Equipped with security features, paddle level switches can be used in applications requiring safety measures, especially in outdoor environments where equipment could be tampered with.
Adjusting the paddle to suit different material densities can be done without the need for special tools. This is a great advantage for users handling various types of bulk materials, like grains or cement, where material characteristics may vary.
Paddle level switches are used in a variety of applications where detecting the presence or absence of bulk solid materials is critical. They are reliable in environments with dusty, granular, or powdery substances. Here are some common applications:
Used in industries like agriculture, mining, and food processing to monitor levels of bulk materials such as grains, cement, pellets, and powders.
Helps prevent overfilling and ensures proper material flow by activating alarms or shutting down conveyors when the bin is full or nearly empty.
In industrial production processes, paddle level switches can control the flow of raw materials like sand, coal, or chemicals to maintain consistent production rates and prevent material shortages.
Used in hoppers to detect material levels and ensure the hopper is not overfilled or runs empty. Commonly seen in plastic manufacturing or recycling processes where plastic pellets or granules are stored.
Paddle switches are often installed in dust collection hoppers or cyclones to monitor when the dust collector needs to be emptied. This is crucial for maintaining proper air filtration and safety.
In silos or bins where dry foods (such as grains, sugar, flour) are stored, paddle level switches can monitor levels to maintain process control and ensure efficient use of storage.
Used to detect levels of heavy, abrasive materials such as sand, rock, or ore in silos, bunkers, or transfer stations. The rugged construction of paddle switches makes them suitable for such harsh environments.
Paddle switches are used to monitor cement, lime, and other powdery materials in storage tanks, ensuring timely replenishment or controlling material discharge for production lines.
In this sector, paddle switches can be used in dry powder processes to control the level of raw materials and intermediates in manufacturing vessels, ensuring accurate dosage and preventing cross-contamination.
A paddle switch is designed for level detection in bulk solids applications. Its primary function is to monitor the level of materials, either to detect when a bin is full or when it is nearing empty. It’s a crucial component in material handling systems to prevent overflows or ensure continuous material supply.
A paddle switch works using a rotating paddle mechanism. Here’s a breakdown of its operation:
  • The paddle is continuously rotating when no material is present.
  • As material accumulates in the container and reaches the paddle, the material’s resistance slows or stops the paddle’s rotation.
  • When this resistance is detected, the switch activates an electrical contact that can trigger alarms, conveyors, or other process control actions.
  • Once the material level falls and no longer touches the paddle, it resumes rotation, signaling that the material level has decreased.
Yes, rotary paddle level switches are considered sensors because they detect material levels and provide feedback based on the presence or absence of material in contact with the paddle. They act as point level sensors, which means they detect when material reaches a specific point in a vessel.
