Open and Closed Tank DP Level Calculations
Open Vessel Level Measurement Calculation
a) Example calculation for the transmitter installed in zero-based direct mount application
The Calibration Range may be computed using the following method:
Zero based direct mount application
At zero percentage of level (for 4mA output)
Pressure = 1.1 X 0 (head level is 0”)
                  At 4 mA = 0”H2O
At 100 percentage of level (for 20mA output)
Pressure = 1.1 X 80”(head level is 80”)
                  At 20mA= 88 ”H2O
The calibration range of the transmitter is  = 0 to 88”H2O(4 to 20mA)
b) Example calculation for the transmitter installed in non- zero-based direct mount application
Non-zero based direct mount application
Pressure  = Head1
  = 1.1 X 10”
At 4 mA  = 11”H2O
pressure = Head2
  = 1.1 x 70”
 At 20 mA = 77 ”H2O
So the calibration range of the transmitter is  = 11’’H2O  to 77”H2O(4 to 20mA)
c) Example calculation for the transmitter installed in non- zero-based remote mount application
Non-zero based remote mount application
Pressure  = Head1
                  = 1.1 X 10”
  At 4 mA= 11”H2O
Pressure  = Head1 + Head2
                  = (1.1 X 10”) + (1.1 X 80”)
=11” + 88’’
  At 20 mA= 99 ”H2O
So the calibration range of the transmitter is  = 11’’H2O  to 99”H2O(4 to 20mA)
Closed Vessel Level Measurement Calculation
Closed Tank Level Calculation with Wet Leg
a) Example calculation for the transmitter installed in zero based direct mount application
The Calibration Range for the DP transmitter is calculated as like below
Closed tank level - zero based direct mount application
Differential pressure   = Phigh – Plow
                                     = 0 – Head1
  = 0 – (1.1 X 80”)
                  At 4 mA= -88”H2O
= Head2 – Head1
 = (1.1 X 60”)] – (1.1 x 80”)
 =66-88
At 20 mA = -22”H2O
Cal. Range = -88 to -22”H2O(4 to 20mA)
b) Example calculation for the transmitter installed in non zero based direct mount application,
DP   = Phigh – Plow
  = Head2 – Head1
  = (1.1 X 10”) – (1.1 X 80”)
  =11” – 88”
 At 4 mA = -77”H2O
DP   = Phigh – Plow
  = (Head2 + Head3) – Head1
  = [(1.1 X 10”) + (1.1 X 50”)] – (1.1 X 80”)
  =11”+55”-88”
At 20 mA  = -22”H2O
Cal. Range = -77 to -22”H2O(4 to 20mA)
c) Example calculation for the transmitter installed in non zero based remote mount application
Non-zero based remount amout application
DP   = Phigh – Plow
  = Head2 – Head1
  = (1.1 X 10”) – (1.1 X 90”)
  =11” – 99”
At 4 mA  = -88”H2O(LRV)
DP   = Phigh – Plow
  = [(1.1 X 10”) + (1.1 X 60”)] –   (1.1 X 90”)
  =11”+66”- 99”
At 20 mA  = -22”H2O(URV)
