Liters per Hour (L/h) to Cubic Meters per Hour (m³/h) Flow Unit Conversion Calculator
Engineers, technicians, and fluid system designers can use this tool to convert Liters per Hour (L/h) to Cubic Meters per Hour (m³/h), therefore helping them to standardize flow measurements for large-scale and international uses.
A metric unit of flow rate called liters per hour (L/h) shows how many liters of fluid move through a spot in one hour. Dosing pumps, irrigation systems, chemical injection, and low-flow metering applications all frequently employ this.
  • Chemical dosing in water treatment facilities.
  • Exact control of fertigation and irrigation in agriculture.
  • Flow measurement in medical and laboratory devices.
  • Industrial machinery’s cooling and lubrication mechanisms.
A standard metric unit, cubic meters per hour (m³/h), denotes the volume of fluid flowing in cubic meters per hour. Widely utilized in infrastructure, energy, and industry, it is appropriate for measuring greater flow rates.
  • Water distribution for industrial and municipal use.
  • Monitoring pipeline flow in oil and gas industries.
  • Hydronic loops and HVAC chilled water systems.
  • Monitoring bulk flow in chemical and industrial facilities.
Use the formula below to convert Liters per Hour (L/h) into Cubic Meters per Hour (m³/h):
Explanation: 1 cubic meter = 1,000 liters,
so dividing by 1,000 gives cubic meters per hour.
If your system outputs 2,500 L/h, convert it to m³/h:
2,500 ÷ 1,000 = 2.5 m³/h
So, a flow of 2,500 Liters per Hour equals 2.5 Cubic Meters per Hour.
Liters per Hour (L/h)Cubic Meters per Hour (m³/h)
1 L/h0.001 m³/h
100 L/h0.1 m³/h
500 L/h0.5 m³/h
1,000 L/h1.0 m³/h
2,500 L/h2.5 m³/h
5,000 L/h5.0 m³/h
10,000 L/h10.0 m³/h
  • Convert small-scale flow measurements to standardized industrial unit.
  • Allow cross-comparison in worldwide initiatives.
  • Increase compatibility across equipment from several vendors.
  • Simplify energy, HVAC, and chemical process design estimates.
  • Help with reporting and regulatory compliance.
For specialists who must convert tiny, exact flow measurements into large-scale, globally accepted engineering units, this conversion tool is absolutely vital.
