Electro Magnetic Flow Meter Installation Calculator: Minimum Length for Reducing Joint
Magnetic flow meters, or mag meters, are widely used to measure the flow of conductive fluids and slurries across various industries, including water treatment, chemical processing, and food and beverage manufacturing. To ensure accurate flow measurements, proper installation is essential. One critical aspect of this installation is calculating the minimum length for reducing joints, which helps maintain a low angle of the flow path transition, reducing turbulence.
This calculator simplifies the process by providing a quick and accurate way to determine the minimum length for reducing joints based on the pipe diameters.
Electro Magnetic Flow Meter Installation Calculator: Minimum Length for Reducing Joint 1
When installing a magnetic flow meter, it’s essential to maintain a low angle at reducing joints to prevent turbulence that could affect flow accuracy. The minimum length of a reducing joint can be calculated using the following formula:
Electro Magnetic Flow Meter Installation Calculator: Minimum Length for Reducing Joint 3
  • L: Minimum length of reducing joint (mm)
  • D: Major diameter of the reducing joint (mm)
  • d: Minor diameter of the reducing joint (mm)
This formula ensures the internal angle of the joint does not exceed 7.5°, maintaining an even flow profile for accurate measurements.
  1. Input the major diameter D of the upstream pipe and the minor diameter d of the downstream pipe.
  2. Calculate the minimum length L required for the reducing joint.
  3. Install the reducing joint based on this length to ensure the flow path transition is smooth and avoids any unnecessary turbulence near the flow meter.
Click here for Electromagnetic flowmeter Calibration procedure
If you have a magnetic flow meter with a pipe diameter of 80 mm (minor diameter) installed downstream of a 100 mm pipe (major diameter), you can calculate the minimum length as follows:
L=(100?80)×7.63=152.6?mm
This means the reducing joint should be at least 152.6 mm long to maintain the angle below 7.5° and ensure accurate flow measurements.
Click here for Electromagnetic Flowmeter Troubleshooting: Identifying and Resolving Issues
  • Maintain measurement accuracy by reducing flow disturbances.
  • Simplify compliance with industry standards.
  • Prevent potential errors due to turbulence at reducing joints.
By following this simple yet effective calculation, users can be confident in their magnetic flow meter installations for optimal performance and reliability
  • Install the mag meter in a straight pipe section, away from flow-disturbing components (e.g., valves, elbows, pumps).
  • Maintain a minimum distance of 3xDN (pipe diameter) upstream and 2xDN downstream of the meter to ensure stable laminar flow.
  • If there’s a valve, position the mag meter downstream of the valve.
  • When reducing joints are used, the internal angle must not exceed 7.5°. To maintain this angle, calculate the minimum length of the joint using the formula:
    L=(D?d)×7.63
  • For a DN80 mag meter installed after a 100 mm pipe, the reducing joint length should be at least 152.6 mm to keep the angle under 7.5°.
  • Ensure the mag meter’s flange connections are assembled concentrically both upstream and downstream to avoid turbulence, which can impact accuracy.
  • Place the washer and grounding ring concentrically.
  • To prevent inaccurate readings due to an empty pipe, avoid installing the mag meter at the highest point or free outlet in the pipeline system, as gravitational effects may cause the pipe to empty.
  • For fluids with particles (e.g., sludge, sewage), install the mag meter vertically with flow direction from bottom to top. This ensures a full pipe condition and reduces the risk of bubbles affecting measurements.
Click here for Electromagnetic Flow Meter Installation – Step-by-Step Guide and Checklist for Accurate Measurements
