Cybersecurity in PLC Systems – Advanced 25 MCQ Quiz
Cybersecurity in PLC systems is now one of the most important problems in the process industries. When plants go digital and connect to the internet from afar, threats like malware, unauthorized access, and network vulnerabilities can put safety, reliability, and production continuity at risk. This difficult quiz is for experienced engineers, control system experts, and cybersecurity professionals who work with PLC and SCADA/DCS systems. You will have to answer 25 hard multiple-choice questions about real-world vulnerabilities, standards (IEC 62443, NIST), defense-in-depth techniques, and how to fix problems. There are extensive answers and explanations for each question to help you learn. Test your knowledge and improve your skills against threats that are always changing in the business world.
Cybersecurity in PLC Systems - Advanced 25 MCQ Quiz
Cybersecurity is no longer an option for PLC systems; it is a must. As challenges to automation grow, process industries must protect their control systems from malware, vulnerabilities, and illegal access. There are 25 challenging multiple-choice questions on this quiz, each with a full answer, that will test your knowledge of real-world protection techniques, IEC 62443 standards, and industrial cybersecurity procedures.
What do anomaly-based Intrusion Detection Systems (IDS) do in PLC networks?
What is the best way to manage patches in PLC systems?
How can you be sure that PLC engineering software is safe before you install it?
What log data is most useful for finding brute force login attempts on PLC HMIs?
What does Security Level (SL) mean in IEC 62443?
Which industrial communication protocol automatically includes encryption and authentication?
What method is used to make sure that PLC backups are safe?
Why do PLC cybersecurity systems use jump servers?
Why should USB ports on PLC engineering workstations not be open?
What insider threat is the biggest danger to PLC cybersecurity?
Why is it so important to sync up time when looking at industrial cybersecurity incidents?
What is the safest way to search for vulnerabilities in PLC environments?
What is the best strategy to keep an eye on PLC ladder logic modifications that aren’t allowed?
What is the best way to characterize a Zero-Trust security approach for PLC networks?
What is the biggest risk of directly connecting PLCs to the company’s IT network
What protocol that is often used in PLC systems is not secure since it doesn’t have encryption or authentication?
What is the best way to keep PLC systems safe while doing maintenance from a distance?
What is the main job of a Whitelist Application Control (WAC) in PLC systems?
What is a big risk when PLC firmware isn’t updated?
What is the main point of “Defense-in-Depth” in PLC cybersecurity?
What kind of malware was designed to attack Siemens PLCs?
What does a Demilitarized Zone (DMZ) do for cybersecurity in process control?
Which concept of network architecture does PLC systems use to reduce cybersecurity threats the most?
The average score is 73%
Refer the below link for How to Safeguard PLCs Against Cyber Attacks in Industrial Networks ?
