Control Valve Basic Terminologies – A Complete Guide
What Is a Control Valve?
A control valve is a mechanical device used in industrial process control systems to regulate the flow rate, pressure, temperature, or liquid level of a process fluid. It works by varying the size of the flow passage in response to a control signal received from a controller, PLC, or DCS.
In a typical control loop, the control valve acts as the final control element, meaning it directly influences the process by opening, closing, or throttling the fluid flow. Control valves are widely used in industries such as oil and gas, power plants, chemical processing, water treatment, pharmaceuticals, and manufacturing.
A control valve consists of three main parts:
  • Valve body – directs the flow of the fluid
  • Valve trim – internal components that regulate flow
  • Actuator – provides the force to move the valve
Depending on the application, control valves can be pneumatically, electrically, or hydraulically actuated, and they are designed to operate safely under varying pressure and temperature conditions.
Understanding control valve terminology is essential for engineers, technicians, operators, and maintenance personnel involved in process automation. Each term describes a specific function, component, or performance characteristic that directly affects valve selection, sizing, operation, and troubleshooting.
Incorrect interpretation of control valve terms can lead to:
  • Improper valve sizing
  • Poor control loop performance
  • Increased energy consumption
  • Premature valve failure
  • Safety and process instability issues
Clear knowledge of terms such as Cv, valve trim, flow characteristics, failure modes, cavitation, seat leakage, and turndown ratio helps professionals communicate effectively across engineering, procurement, installation, and maintenance teams.
From an industry and compliance perspective, control valve terminology is also crucial for:
  • Interpreting datasheets and specifications
  • Following ANSI, ISA, and IEC standards
  • Performing accurate FAT, SAT, and commissioning
  • Ensuring process safety and reliability
In short, mastering control valve terminology improves system efficiency, operational safety, maintenance accuracy, and overall plant performance.
Actuator
An actuator is a pneumatic, hydraulic, or electric device that provides the force and motion required to open or close a control valve. It converts the controller’s signal into mechanical movement of the valve stem or shaft.
The bench set of a control valve actuator is the air pressure range required to stroke the valve from fully closed (0%) to fully open (100%) under no-load conditions. Bench set pressure does not include additional forces such as process pressure or valve packing friction.
The closure member is the movable internal component such as a plug, ball, disc, or vane that directly controls fluid flow by changing its position within the valve body.
The flow coefficient (Cv) is a numerical value that indicates a control valve’s flow capacity. It represents the amount of flow through the valve at a specific pressure drop and is primarily dependent on valve size and internal geometry. Cv is widely used for control valve sizing and performance prediction.
The valve trim consists of all internal parts that come into contact with the process fluid and directly regulate flow. Different trim designs are used to handle various service conditions.
  • Anti-Cavitation Trim: Designed to reduce cavitation by controlling pressure drop stages within the valve.
  • Anti-Noise Trim: Minimizes aerodynamic noise generated by high-velocity fluid flow.
  • Balanced Trim: Reduces the effect of fluid forces acting on the valve plug, allowing smaller actuators.
  • Reduced Trim: Provides a smaller effective flow area than the valve’s nominal size.
  • Soft-Seated Trim: Uses elastomeric or plastic materials to achieve tight shutoff with low actuator force.
Characterized trim is specially designed to produce a predefined flow characteristic such as linear or equal percentage. When combined with a characterized plug or disc, it ensures accurate control, especially in throttling applications requiring high close-off capability.
Erosion-resistant trim is manufactured using hardened materials and optimized geometry to withstand abrasive or high-velocity fluids, significantly extending valve service life.
The failure mode defines the position a control valve moves to when actuating energy (air, power, or hydraulic pressure) is lost.
  • Fail-Close (FC): Valve moves to the closed position on failure.
  • Fail-Open (FO): Valve moves to the open position on failure.
  • Fail-in-Place (FL): Valve remains in its last position when energy is lost.
A fail-safe control valve is designed to move to a safe position open, closed, or locked during emergencies. Achieving fail-safe action may require spring actuators, solenoid valves, or auxiliary air systems to protect personnel and equipment.
The vena contracta is the point downstream of an orifice where the fluid stream reaches maximum velocity and minimum cross-sectional area. At this point, static pressure is at its lowest.
Throttling is the process of regulating flow by partially opening or closing the valve. This creates a controlled pressure drop across the valve, allowing precise flow control.
Valve travel refers to the linear or rotary movement of the closure member from fully closed to fully open position, usually expressed as a percentage.
Valve gain describes the relationship between valve travel and flow rate. It is represented by the inherent or installed flow characteristic curve and plays a crucial role in control loop stability.
A valve is said to have dual seating when it uses both soft seating (primary seal) and metal-to-metal seating (secondary seal). This design provides tight shutoff with backup sealing, typically achieving ANSI Class IV leakage.
Flow characteristics define the relationship between valve opening and flow rate.
  • Inherent Characteristics: Measured under constant pressure drop conditions.
  • Installed Characteristics: Actual performance when the valve is installed in a system with piping, pumps, and fittings.
Flow characteristics are achieved by shaping valve plugs, cages, or orifices.
Reverse acting behavior depends on the device:
  • A reverse-acting actuator retracts the stem when diaphragm pressure increases.
  • A reverse-acting valve opens when the plug moves downward.
  • In a reverse-acting positioner, the output signal decreases as the input signal increases.
Reverse flow occurs when fluid flows opposite to the valve’s standard direction. This typically results in higher pressure drop. Many rotary valves are designed to be bi-directional.
The stem guide is a bushing that aligns the valve stem with the seat. Proper stem guiding is essential to minimize packing wear and leakage.
Supply pressure is the air pressure provided to pneumatic instruments such as actuators, positioners, and controllers. The standard instrument air range is 3 to 15 psig (0.2 to 1 bar).
The turndown ratio is the ratio between the maximum and minimum controllable flow rates of a valve.
Example:
Maximum flow = 100 GPM
Minimum flow = 10 GPM
Turndown ratio = 10:1
Seat leakage is the amount of fluid that passes through a control valve when it is fully closed under specified pressure and temperature conditions.
Seat leakage classes define allowable leakage rates and are standardized by ANSI/FCI 70-2 (formerly ANSI B16.104).
The liquid pressure recovery factor (FL) indicates how much pressure is recovered downstream of the vena contracta in non-vaporizing liquid service. It is used along with Cv to evaluate cavitation and flashing tendencies.
The valve body is the primary pressure-containing part of a control valve. It provides the flow passage and houses the internal trim components while withstanding process pressure and temperature.
The bonnet is the valve component mounted on top of the body that encloses the stem and packing. It allows maintenance access and supports stem alignment.
The valve stem connects the actuator to the closure member and transmits motion to open or close the valve.
Packing is a sealing material installed around the valve stem to prevent process fluid leakage to the atmosphere while allowing smooth stem movement.
A valve positioner is a device that ensures accurate valve positioning by comparing the control signal with the actual valve stem position and correcting any deviation.
Cavitation occurs when the fluid pressure drops below its vapor pressure, causing vapor bubbles to form and collapse. This leads to noise, vibration, and severe trim damage.
Flashing happens when vapor bubbles formed inside the valve do not collapse downstream and remain in vapor phase, resulting in continuous erosion of valve internals.
Rangeability is the ratio of the maximum controllable flow to the minimum controllable flow at acceptable accuracy. It indicates how effectively a control valve can operate over a wide flow range.
Dead band is the range of input signal change in which no noticeable valve movement occurs, reducing control accuracy.
Hysteresis is the difference in valve position for the same control signal when approached from increasing versus decreasing directions, usually caused by friction or mechanical play.
The pressure rating defines the maximum allowable working pressure of the valve body at a specified temperature, based on industry standards.
The shutoff class defines the allowable leakage rate when the valve is fully closed, as specified by ANSI/FCI standards.
The control range is the span of flow over which the valve can maintain stable and accurate control without oscillation.
Linearity describes how closely the actual valve flow follows its intended flow characteristic across the entire travel range.
Stroking time is the time required for a valve to move from fully closed to fully open or vice versa, affecting control loop response speed.
The spring range is the pressure range over which the actuator spring balances diaphragm force to position the valve correctly.
Installed gain is the effective valve gain when the control valve operates within an actual process system, including piping and equipment effects.
Understanding these control valve terminologies is essential for engineers, technicians, and maintenance professionals involved in process control, valve selection, sizing, and troubleshooting. Mastery of these concepts leads to better system performance, improved safety, and longer equipment life.
