Table of Contents
Differential pressure transmitter is an instrument used in industries to measure the flow. Calibration procedure of DPT transmitter is what we are going to discuss
Equipments required
- 24 VDC power supply
- Multimeter digital
- Pneumatic hand pump
- Low pressure hand pump
- High precision digital test gauge
- HART communicator
- Remove the differential pressure transmitter from the process
- Make sure the equalizing valve manifold is closed.
- Connect the transmitter with the calibration equipments as shown in fig
- Apply the LRV pressure with the hand held test pump and check the multimeter reading
- If it is not 4ma then calibration is required
If transmitter is analog transmitter
- By applying 0% pressure by test pump adjust the zero pot in transmitter to get 4ma output in multimeter.
- Apply 100% pressure and adjust span pot to get 20ma in multimeter.
- Check for 25%,50%,75%.
- Repeat the process to ensure that no error is occurred.
In case of SMART Transmitter
We have to use HART communicator, connect the communicator with the transmitter select the HARTÂ Â Â Â Â Â Â Communicator Menu for lower range value trim and upper range value trim.
- Basic Set up – Calibration – Zero Trim/Sensor Trim —Lower/Upper range value trims.
- HART communicator will automatically calibrate the transmitter.
- Restore the process connection
- Take the transmitter on line. Ensure there is no leak
