Bar to Torr Pressure Unit Conversion Calculator
This calculator allows you to quickly convert pressure values from Bar to Torr, ideal for scientific, industrial, and engineering applications.
A Bar is a metric unit of pressure, defined as 100,000 Pascals (Pa). It is commonly used in engineering, meteorology, and process control to represent pressure on a larger scale.
A Torr is a unit of pressure equal to 1/760th of standard atmospheric pressure, or approximately 133.322 Pascals (Pa). It is frequently used in vacuum measurements and scientific research.
Suppose you have a pressure of 1.2 Bar.
To convert it to Torr:
1.2×750.062=900.0744?Torr
So, 1.2 Bar is approximately equal to 900.07 Torr.
BarTorr
0.1 Bar75.0062 Torr
0.5 Bar375.031 Torr
1 Bar750.062 Torr
1.5 Bar1,125.09 Torr
2 Bar1,500.12 Torr
5 Bar3,750.31 Torr
10 Bar7,500.62 Torr
  • Vacuum Systems: Convert Bar readings to Torr for accurate vacuum measurements in laboratories and industrial applications.
  • Engineering Applications: Ideal for converting pressure from Bar to Torr in industrial process control and system monitoring.
  • Scientific Research: Use in atmospheric pressure experiments and scientific studies requiring precise pressure conversions.
This Bar to Torr conversion calculator is a convenient tool for engineers, scientists, and technicians working across various fields that require accurate pressure measurements.
