Table of Contents
- Why do we use a normally closed push button as a stop PB?
- What do you mean by Normally-Open Contact?
- What do you mean by Normally-Closed contact?
- Why we must use Normally-Closed Contacts for Stop Push Buttons?
- Using a stop Push Button as a Normally Closed
- Why is the emergency switch in electrical circuits wired with NC contacts?
- Safety
- Fail-safe design
- Standardization
- Logical operation
- Troubleshooting
- Why the Emergency Button is in Normally Closed Condition?
- What are NO and NC in the push button?
- What are a Stop Button and an Emergency Button?
- What is the difference between NO and NC contacts?
- Why Emergency Stop Button is in red color?
- Usually, this stop PB stays in closed condition; it should be operated to make the machine stop or halt.
- If it is in NO state, then the machine may run in the event of open circuit in the wire due to lose connections or breakage.
- Usually, we use two kinds of Digital Inputs to design an electrical circuit using a PLC or any relay such as
a. Normally Open (NO) contact,
b. Normally Closed (NC) contact.
- But the most important thing is everyone must know about the meaning and exact difference between these two switches.
- The Stop Push Button is a Normal Push Button to stop a process, it can be used as an Emergency Push Button.
- Normally-Open Contact is a type of contact when relay gets powered up it closes the respective circuit and permits the flow of electricity through it.
- This switch opens itself and restricts the flow of electricity through it when relay gets de-energized.
- Observe the circuit shown below,
- In an open condition, when the relay gets energized, the contact gets closed to permit the current from the source to the lamp making the lamp glow.
- The lamp gets turned off when the contacts get opened, & the relay is now de-energized.
- Normally-Closed Contact is a type of contact when relay gets powered up; it opens the respective circuit and blocks the flow of electricity through it.
- This switch closes itself and permits the flow of electricity through it when relay gets de-energized.
- In a closed condition, when the relay gets energized, the contact gets opened to restrict the current flow and doesn’t allow the lamp to glow.
- The lamp gets turned on due to the flow of current when the contacts get closed, & relay is de-energized.
In the above section we have studied the basic concepts. Now let us see.
In this section, we will consider three essential elements.
- Start Push Button
- Stop Push Button
- Electrical Motor
Consider an ideal circuit shown in the image below.
In this circuit,
- The Start Push Button (PB) is normally open.
- The stop push button (PB) is normally closed.
- An imaginary motor is triggered through the relay device
- An electrical power supply is allowed to flow from start PB to Stop PB and then to relay to trigger when this Start Push Button is pressed.
- The relay contact gets closed & the circuit is latched.
- Here the power continues to flow from the relay contact even after releasing the Start Push Button.
- Now, we need to press the Stop Push Button to terminate or restrict the power flow.
- On pressing the Stop Push Button de-latch relay gets opened to stop the flow of the power supply as both relay contacts, & the start push button are in the open state.
- The stop push buttons are mechanical type switches, these switches behave like a closed switch.
- When this switch is pressed the circuit gets opened and the power flow is restricted
Here the switch provides a better advantage.
- If the pushbutton malfunctions,the contact behaves as open so that there is no power flow.
- This makes the operator troubleshoot the system. This makes the motor remain safe in off condition due to improper stop push button functionality.
Safety
- The main reason for using NC contacts is safety. When the emergency or stop push button is at rest (not pressed), the NC contacts are closed.
- In this state, the circuit is complete, allowing current to flow through the control system and keep the machinery operational.
- If there is any fault or emergency situation, a person can simply press the button, which will break the NC contacts, and the circuit will open, immediately cutting off power to the machinery and stopping it.
- This ensures a quick and reliable response to emergencies, preventing potential accidents or injuries.
Fail-safe design
- NC contacts have a fail-safe design.
- If there is any open circuit due to wire breakage or cut when using NC contact in a circuit, the circuit naturally opens and prevents the passage of current in the circuit and addresses the failure scenario and keeps machinery in safe condition.
Standardization
- The use of NC contacts for emergency or stop functions has become an industry standard and is often required by safety regulations and standards.
- Standardization helps ensure consistency and makes it easier for operators and maintenance personnel to understand the functionality of the push button.
Logical operation
- The use of NC contacts is intuitive for operators. Pushing the button causes it to break the circuit, which is a natural response in an emergency situation.
- This simplicity reduces the chance of human error during critical moments.
Troubleshooting
- If there is a problem with the control system, NC contacts that are stuck open will prevent the machinery from starting, alerting maintenance personnel to investigate the issue before the equipment is operated again.
- During electrical control system design normally closed contact is selected and considered as best for emergency stop.
- The machine stops working if and only if there is a failure of the emergency stop part of the line with minimum loss.
- Basically, a switch is provided with single input and a single output.
- The switch may be Normally Open (NO) or Normally Closed (NC) type.
- NC/NO switch consists of single input and double outputs with two consequent actions.
- A general-purpose switch is a spring-return type switch used to start and stop the respective machine from a functional point of view.
- But an emergency stop button is considered a safety device to stop harmful activities to safeguard the plant equipment, & personnel safety.
- NO contact is Normally Open, this closes when the coil is energized.
- NC contact is Normally Closed, this opens when the coil is energized.
- Basically, we all know that an emergency stop push button breaks the power supply in case of any hazardous moment.
- These emergency stop push buttons are coated in red color so that it can
tobe identified immediately during any emergency.
