What is a Fire alarm control panel and how does it work?
Introduction to fire alarm system:
A Fire Alarm Control Panel (FACP), also known as a Fire Alarm Control Unit (FACU), Fire Indicator Panel (FIP), or simply a fire alarm panel, is the central component of a fire alarm system. This panel receives signals from devices that detect and report fires, monitors the system’s functionality, and automatically controls equipment as needed. It also transmits information to prepare the facility for a fire according to a predefined sequence. Additionally, the panel may supply power to operate connected initiating devices, notification appliances, controls, transmitters, or relays. There are four main types of panels: coded panels, conventional panels, addressable panels, and multiplex systems.
A fire alarm system would be composed of several devices and all of these devices would work together to inform people in case of fire, smoke, or other emergencies. Mostly smoke and heat detectors would activate these alarms. A fire alarm system is necessary to protect a building and also the people in it. This would be really useful to prevent the loss of life and property in case of fire in the building.
Fire alarm control panel:
The fire alarm control panel is also called a fire alarm control unit. Basically, it is the controlling component of a fire alarm control system. This can be described as the hub of the fire alarm system. It would monitor the environment with the help of several sensors and also would take action in case of any emergency situation. The fire alarm control panel would have a power supply, and it would also have initiating and notification circuitry.
What are the major components of a Fire alarm control panel?
Input devices:
There would be several input devices in a fire alarm control panel. The input devices could be smoke detectors or manual pull stations. The input device is the device that would give a signal to the control panel in case of any variation in the condition. These input devices are also called initiating devices because it would take the first initiative during a change in their surroundings. The input devices should determine the condition of the fire like how fatal it could be. Based on this, preventive measures would be taken.
Circuitry:
The input devices would be connected to a circuit and it would transmit a signal in case of any variation in its surroundings. This circuit would be connected to the input device such as a smoke detector
Output devices:
In a control panel, the major purpose of an output device is to notify in case of any emergency situation. The output device could be an alarm, a light or a beacon. The output device would be connected to a circuit. This is called the notification device in a fire alarm system.
The control panel would be connected to the power supply to operate properly. The device which is connected to the control panel would utilize this power. There is also a secondary power supply and this is utilized as a backup in case there is any primary power failure.
What are the major functionalities of a Fire alarm control panel?
  • It will detect any fire or smoke
  • It would alert the people in case of any emergency
  • It would alert the fire department
  • It would automatically activate the fire suppression system
What are the different types of Fire Alarm Control panels?
Coded Type:
The Coded panel is almost the same as the modern conventional panel. This type of panel would have a motor or an electronic pulse generator. When the motor operates the code wheel will rotate. The code wheel is connected to individual zones in a building. During the rotation of the code wheel,it would make changes in the pulse generator and this will provide the code of the box.
Conventional Fire alarms:
This type of alarm system is not suitable for bigger buildings mostly it is utilized in small structures. It would alarm in case of any emergency situation. This type of control panel is less expensive and also it can be easily installed.  In this panel, there would be several LEDs and each LED represents different zones in the building. Each zone in the building would have smoke detectors and in case of any heat or smoke, it would transmit a signal. This type of control panel has a simple control unit and the initiating and notification devices would be connected to the dedicated circuitry.
Multiplex system panels, which emerged as a transitional technology between conventional and modern addressable systems, were commonly used in large buildings. Initially, these systems were designed to function like large conventional systems. However, as technology advanced, later installations began incorporating components and features of modern addressable systems. Multiplex systems often had the capability to control more than just the building’s fire alarm system, including HVAC, security systems, and electronic door locks, even without any active alarm or trouble conditions. The main panel served as the central control unit, but fire alarm controls were typically accessed through transponders smaller conventional panels programmed to communicate the status of specific system parts to the main panel. These transponders also allowed access to basic fire alarm control functions.
Programmable type:
This type of system can be defined as a system that is designed according to the customer’s requirements. The circuit in this panel is programmed for fire, smoke, etc. So in the programmable type, the input and the output circuitry are programmed for specific requirements.
Fire Alarm Programmable type
Addressable Fire alarms:
This is another type of fire alarm control panel and it is utilized in bigger buildings such as Shopping-malls. This type of fire alarm system would require less wiring when compared to the conventional type. This system, has a signaling line circuit and it would provide power to the devices which are connected to the control panel, and also communication can be carried out.
The devices in the fire alarm control system such as alarms, detectors, etc. would have a unique number. In this type of fire control panel system, all the input and output devices are connected to the fire alarm control panel. In this type of control panel, the devices which are connected to the control panel signal the control panel in case of any emergency situation. The Control panel can control each device that is connected to it.
Intelligent control panel:
This type of system is called an addressable system in this system it would transmit the data from the sensors in the building or the structure. So the detector would transmit all the details regarding the smoke level. It would have data from each detector.
Addressable fire protection panels utilize advanced technology, allowing for precise programming and control. Each connected device is assigned a unique address, enabling quick and easy identification of the signal source.
There are three primary types of signals that a fire alarm control panel can receive:
This indicates a potential fire, triggering audio and visual alarms and notifying the authorities.
This alerts building staff to an issue that may hinder the proper functioning of the alarm system.
This serves as a warning of problems with wiring, battery, or the panel’s communication system.
Networking fire alarm control panels involves connecting multiple panels to create an integrated system. This setup allows inputs on one panel to trigger outputs on another or enables centralized monitoring of various systems. Networking is particularly useful in scenarios where a single panel is insufficient or in multi-building setups. It also helps decouple systems, minimizing the risk of extensive facility downtime due to system failure or maintenance.
Sub-networks can be established using hardware or software architectures, but implementing networked systems typically requires more investment, training, and careful configuration. While there are quasi-standards that allow panels from different manufacturers to be networked, compatibility isn’t guaranteed across all companies. One widely used protocol is BACnet, common in various industrial networks. Systems commonly interconnected with the Fire Alarm Control Panel include HVAC, Building Automation Controllers, Security/Access Control, and Elevator Controllers. The Arcnet protocol has long been utilized in industrial applications and is also used for networking Fire Alarm Control Panels.
Recently, some panels have begun using standard Ethernet for networking, though this practice is not yet widespread. Some organizations opt to develop proprietary protocols, which offer the flexibility to innovate and extend the technology. Typically, a bridging layer between the proprietary network and BACnet is available for added compatibility.
Fire alarm control panels offer several important functions to manage system operations:
This function clears alarm conditions and resets all devices. If an alarm condition persists, the panel may re-trigger the alarm or refuse to reset until the issue is resolved.
The acknowledge function is used to respond to alarms, troubles, or supervisory signals manually. It stops the panel’s internal sounder and changes the flashing LED to a steady state, indicating that the issue has been noted.
Signal silence, also known as alarm silence, deactivates or mutes the alarm sounds, while visual signals like strobes may continue. This function helps emergency responders communicate during an incident and is often followed by a system reset.
The lamp test checks the functionality of the panel’s indicator lights (LEDs). This test is typically required on multi-zone panels and is sometimes automatically performed during a system reset.
The walk test allows a technician to test fire alarm devices throughout a building. When a device is activated, the panel may briefly sound the alarm or flash lights before automatically resetting.
The drill function activates the system’s alarms for fire drills without sending a signal to the fire department. This function is commonly used for practice evacuations in schools and other facilities.
The class change function briefly sounds alarms to signal class changes or breaks in schools. This helps familiarize students with the alarm sound and ensures the notification circuits are regularly tested.
Difference between Conventional and Addressable fire alarm control panels?
Conventional Fire AlarmAddressable Fire Alarm
In the conventional type the initial cost is very lowAddressable type is really easy to install
In the conventional type we can see a lot of compatible devicesIn the addressable type we would get more information
Conventional type is harder to programAddressable type is easier to program
Conventional type is mostly used for smaller buildingsAddressable type can be used for bigger ones
More cabling is required for the conventional panel typeLess cabling is required for the addressable panel type
Testing your fire alarm control panel is crucial for ensuring the system is functioning correctly. Follow these steps to test your fire alarm using the alarm panel key:
  1. Insert the test key into the bottom of the fire alarm point.
  2. At the panel, turn the key anti-clockwise to begin the test process.
  3. The access LED on the panel should illuminate, indicating the system is in test mode.
  4. Press the red silence key to mute the alarm sound during the test.
  5. Push the fire alarm point upwards to reset it after testing.
  6. Press the green reset key on the panel to complete the test and return the system to its normal operating mode.
Always follow safety protocols and ensure the fire alarm system is functioning properly after testing.
What are the applications of fire alarm control panels?
  • It would notify in case of any emergencies
  • Structural damage and life fatality can be avoided
  • Alarming and evacuation can be easily done
  • Fire extinguishing by notifying the sprinkler system
  • Fire and smoke control
  • It will alert us in case of any hazards
  • It can protect our property and our lives
What are the advantages of a fire alarm control panel?
  • It would interact with other systems
  • It would give a proper warning
  • It would communicate with several fire sensors
  • It would notify really quickly in case of any hazards
  • it can prevent damage to the structure and other assets in it
  • It can save several lives
  • Monitoring costs can be decreased by this system
  • It can activate the sprinkler system automatically
The Fire Alarm Control Panel (FACP), also known as the Fire Alarm Control Unit (FACU), Fire Indicator Panel (FIP), or simply the fire alarm panel, is the central component of a fire alarm system. It is used to monitor signals from fire detection devices, activate alarms to alert occupants and emergency services, and manage associated systems like HVAC and security. The FACP ensures that the building is properly protected and that appropriate actions are taken in the event of a fire or emergency.
Various Manufacturers of the Fire alarm control panel?
  • Edwards signaling
  • United Technologies Corp
  • Honeywell
  • Fike Corp
  • Bay Alarm
  • Kidde fire protection
  • NAPCO Security Technologies Inc
  • Potter Electric signal
  • Pacific Fire and Security
  • Cooper
