Top 25 Advanced MCQs on Boiler Control & Interlock Logic for Instrumentation and Control Engineers
This advanced quiz on Boiler Control Systems and Interlocks is for instrumentation and control engineers who want to test and improve their knowledge. It has 25 hard multiple-choice questions about how boilers work, control loop logic, safety interlocks, burner management systems (BMS), and how to start and stop a boiler. There is a detailed explanation after each question to help you comprehend and use what you’ve learned. This quiz helps you remember important ideas in current boiler automation systems, whether you’re getting ready for an interview, a certification, or just want to brush up on what you already know. Jump in and see how well you know one of the most important parts of the plant!
Welcome to the Advanced Boiler Control Systems and Interlocks Quiz! This test has 25 questions that will test your understanding of boiler process control, safety interlocks, loop methods, and burner management systems. This test is for experienced instrumentation and control engineers. Each question has a detailed answer that helps you remember important ideas and how to use them in real life. Are you ready to test your skills? Let’s get started!
1 / 26
What signal is usually needed to allow the boiler to start up?
2 / 26
Why do most people choose hardwired or certified safety PLCs for interlock logic?
3 / 26
Which of the following loops usually causes the boiler to shut down completely?
4 / 26
The boiler master control is used to:
5 / 26
What happens when the low fuel gas pressure interlock goes off?
6 / 26
A sudden rise in furnace pressure without a rise in firing rate while the boiler is running may mean:
7 / 26
What is the most important thing that logic solvers that handle fuel shutoff functions must do in SIL-rated boiler burner management systems?
8 / 26
What happens to a three-element drum level system if the feedwater flow transmitter doesn’t work right?
9 / 26
Why is there a minimum airflow interlock before letting fuel into the boiler?
10 / 26
A high steam pressure interlock in a boiler usually causes:
11 / 26
What is a good rationale to use a two-out-of-three (2oo3) voting logic on drum level transmitters in important boiler applications?
12 / 26
Which loop in a normal boiler keeps the combustion stable when the load changes?
13 / 26
A flame scanner stops working when the heating system is running normally. What should happen?
14 / 26
The combustion control on a boiler is set up using cross-limited air/fuel ratio control. What is the main reason for cross-limiting when the load changes?
15 / 26
What kind of logic controller do burner management systems (BMS) usually use?
16 / 26
A master fuel trip (MFT) will usually happen when:
17 / 26
What interlock in a dual-fuel burner makes sure that only one fuel can be used at a time?
18 / 26
In a triple-redundant flame detection system used in important boilers, what logic is usually employed to check for the presence of flame?
19 / 26
What is the most typical standard for safety interlocks in boilers and burners?
20 / 26
What does a purge cycle do before the boiler starts?
21 / 26
What are the usual parameters for the “three-element” drum level control?
22 / 26
What does a “low drum level” interlock usually do to the way a boiler works?
23 / 26
24 / 26
Which instrument do most modern boilers employ to find flames?
25 / 26
Which control loop in a boiler system is usually called a safety interlock?
26 / 26
What is the main job of a burner management system (BMS) in a boiler?
The average score is 60%
Click here for Explore 30+ Instrumentation and Control: Engage with Our Interactive Learning Quiz!
