Advanced Quiz on Thermocouple Troubleshooting in Process Area
Thermocouples are the most important tool for measuring temperature in process industries. However, when readings go wrong, fixing them becomes both an art and a science. This advanced quiz tests your understanding of your area by giving you real-life troubleshooting problems from refineries, chemical plants, and power stations. The questions are meant to see how well you comprehend open circuits, cold-junction problems, grounding faults, signal drift, and calibration discrepancies. This quiz will help you become more confident and better at diagnosing problems with thermocouples in the field, whether you work as a maintenance engineer or a commissioning specialist. Get ready to deal with real-life situations where every degree matters!
Great job! You’ve put your thermocouple troubleshooting skills to the test in real-life situations. Each question is based on problems that real process plants have, like wiring polarity and grounding loops. Keep improving your diagnostic methods to make sure that every industrial setting has safe processes and reliable temperature control.
A thermocouple installed in a reformer furnace shows a steady 250°C even after furnace shutdown and cooldown. The cable and transmitter test normal, and the sensor body is cold to touch. What’s the most likely cause?
A dual thermocouple installed in redundant loop shows mismatch between channels. Both are Type K. Why?
In an ammonia synthesis loop, a Type K thermocouple installed in a thermowell reads 80°C lower than expected. When checked with a handheld calibrator at junction box, the mV matches correct temperature. What does this indicate?
A thermocouple in a distillation column shows slow temperature rise after startup. Possible issue?
A thermocouple shows correct mV on multimeter but wrong DCS reading. Cause?
Why should thermocouple transmitters be mounted near sensors?
A Type N thermocouple installed in a gas turbine exhaust shows sudden jumps of +200°C whenever a nearby variable-frequency drive (VFD) starts. Shielding and grounding appear correct. Cable length is 80 m. What’s the most probable root cause?
A thermocouple installed near a hydrogen reformer furnace frequently fails within weeks — open circuit each time, even with high-quality MI cable. What’s the most probable reason?
A batch reactor has two redundant thermocouples wired to different transmitters. During a CIP (Clean-In-Place) cycle, both readings suddenly jump by +100°C for 10 seconds, then normalize. No process heat applied. What’s the likely reason?
When a thermocouple is installed in a moving fluid line, poor response time indicates:
Thermocouple insulation damage at high humidity may cause:
A thermocouple transmitter shows 20 mA output for a cold line. Cause?
What’s the effect of connecting thermocouple shield at both ends?
Why do thermocouple readings drift over time in high-temperature service?
A transmitter shows burnout indication. The thermocouple was verified good. What should be checked next?
In a batch reactor, a thermocouple signal drops suddenly to zero during cleaning cycle. Why?
A thermocouple shows reading only when the transmitter body is touched. What’s the likely fault?
A grounded thermocouple shows erratic spikes when connected to PLC. What is the best corrective action?
A high-pressure reactor thermocouple reads 60°C lower than expected during a heat-up cycle. Calibration and loop check are perfect. Process engineer confirms no heat loss. What’s the next best diagnostic step?
Two thermocouples on the same process show different readings. Both verified okay in calibration. Possible reason?
A thermocouple is reading 50°C higher than actual. Reference junction compensation is internal. What could cause this?
In a vacuum distillation column, a thermocouple installed inside a long thermowell shows sluggish and damped response compared to another nearby probe. Process temperature fluctuates rapidly. What should be checked first?
During maintenance, the polarity of thermocouple extension cable was reversed. What symptom would appear on the control system?
During startup of a fired heater, a Type K thermocouple connected to a safety interlock system shows a steady 400°C while actual flame temperature exceeds 800°C. The interlock didn’t trigger. Field check shows 8.5 mV output. What’s the root cause?
A type K thermocouple in a reactor shows 0°C on DCS though process is 250°C. Loop test shows 0 mV. What’s the most probable fault?
The average score is 65%
Tags
#Thermocouple, #InstrumentationQuiz, #TemperatureMeasurement, #Troubleshooting, #ProcessInstrumentation, #MaintenanceEngineer, #ColdJunction, #GroundLoop, #IndustrialAutomation
