Standard Atmospheric Pressure (atm) to Psi Conversion Calculator
This tool helps you convert pressure values from standard atmospheric pressure (atm) to pounds per square inch (psi):
The standard atmosphere (symbol: atm) is a unit of pressure defined as 101,325 pascals (Pa), representing the average atmospheric pressure at sea level.
A pound-force per square inch (symbol: psi) is a unit of pressure used in the imperial and US customary systems, defined as the pressure from a force of one pound-force applied over an area of one square inch.
Suppose you have a pressure of 2 atm.
To convert it to psi:
2×14.6959=29.3918 psi
So, 2 atm is equal to 29.3918 psi.
Standard Atmosphere (atm)Psi (pound-force per square inch)
0.5 atm7.34795 psi
1 atm14.6959 psi
2 atm29.3918 psi
5 atm73.4795 psi
10 atm146.959 psi
20 atm293.918 psi
50 atm734.795 psi
100 atm1469.59 psi
  • Engineering Applications: Convert pressures in various industrial systems like HVAC and pneumatics.
  • Instrumentation: For converting gauge readings from metric units to imperial units.
This calculator is essential for engineers, technicians, and others who require accurate pressure conversions.
