Ratio Control System MCQs in Industrial Instrumentation
Welcome to the “Ratio Control System in Process Instrumentation” quiz! Designed for process industry professionals and enthusiasts, this quiz tests your advanced understanding of ratio control systems, a critical component in optimizing industrial processes. You will encounter 25 multiple-choice questions, each with detailed answers and explanations to deepen your knowledge. Topics range from the principles of ratio control to its applications in maintaining process stability and efficiency. Whether you are an experienced engineer or a learner exploring process instrumentation, this quiz offers an excellent opportunity to assess and enhance your expertise. Let us get started and master ratio control systems!
Dive into the world of ratio control systems in process instrumentation! This advanced quiz features 25 MCQs, complete with answers and explanations, to test your knowledge of maintaining precise process ratios in industries. From basic concepts to practical applications, challenge your skills and gain valuable insights into this essential industrial control mechanism. Begin your learning journey today!
1 / 27
In a chemical reaction, reactants X and Y must be mixed in a 2:5 ratio to optimize the reaction’s yield. Due to a sensor failure, the flow rate of X cannot be measured accurately. What steps should you take to ensure the ratio is maintained?
2 / 27
A paper mill uses ratio control to maintain a 4:1 ratio of water to pulp for the papermaking process. During a batch run, the pulp flow rate fluctuates due to a blockage in the feed line. What action should the ratio control system take?
3 / 27
In a fuel-air mixture system for a boiler, the air supply fan speed increases due to a power surge, causing the air-to-fuel ratio to deviate from the optimal value. How should the ratio controller respond?
4 / 27
you are operating a blending system where two chemicals, A and B, must be mixed in a 1:3 ratio (A:B) to produce a product with the desired quality. During operation, the flow rate of chemical A suddenly drops due to a pump issue. What should the ratio control system do?
5 / 27
What type of controller is most commonly used in ratio control systems?
6 / 27
Ratio control is unsuitable when:
7 / 27
The term “secondary flow” in ratio control refers to:
8 / 27
An incorrect ratio in a chemical reaction could result in:
9 / 27
What determines the primary variable in ratio control?
10 / 27
A ratio control system’s response to disturbances is faster when paired with:
11 / 27
Which process industry heavily relies on ratio control systems?
12 / 27
The main advantage of ratio control is:
13 / 27
How is the secondary variable in ratio control determined?
14 / 27
Ratio control can be considered a subset of:
15 / 27
Which sensor is crucial in a ratio control loop?
16 / 27
The ratio controller output adjusts:
17 / 27
Ratio control is particularly useful in blending systems because:
18 / 27
A deviation in the controlled ratio typically indicates:
19 / 27
Which parameter is typically measured to control the air-fuel ratio in combustion systems?
20 / 27
The setpoint in a ratio control system is expressed as:
21 / 27
Ratio control systems are often paired with:
22 / 27
What happens if the ratio setpoint in a system is incorrect?
23 / 27
In a fuel-air mixture control system, the ratio controller ensures:
24 / 27
Ratio control is most commonly used in:
25 / 27
Which of the following components is essential in a ratio control loop?
26 / 27
What is the primary purpose of a ratio control system in process industries?
27 / 27
In a ratio control system, the manipulated variable is typically:
The average score is 85%
Click here for More Instrumentation and control Quiz
