This calculator allows you to convert pressure values from pounds per square inch (psi) to Torr (mmHg).
Definition: Pound-force per Square Inch (psi)
Definition: Torr (mmHg)
A Torr (symbol: Torr), also known as millimeter of mercury (mmHg), is a unit of pressure named after Evangelista Torricelli. It is defined as the pressure exerted by a 1 mm high column of mercury at 0°C under standard gravity. It is commonly used in vacuum measurements and low-pressure applications.
Formula for Psi to Torr Conversion:
Pressure in Torr=Pressure in psi × 51.7149
How to Convert Psi to Torr: Example Calculation
Suppose you have a pressure of 14.696 psi (which is equivalent to atmospheric pressure at sea level).
To convert it to Torr:
14.696×51.7149=760?Torr
So, 14.696 psi is equal to 760 Torr.
Quick Reference Conversion Table for Psi to Torr
Pound-force per Square Inch (psi) | Torr (mmHg) |
1 psi | 51.7149 Torr |
5 psi | 258.5745 Torr |
10 psi | 517.149 Torr |
14.696 psi | 760 Torr |
20 psi | 1034.298 Torr |
50 psi | 2585.745 Torr |
100 psi | 5171.49 Torr |
Use of Psi to Torr Conversion Calculator:
- Vacuum Systems: Convert pressures in psi to Torr for accurate vacuum level measurement and monitoring.
- Instrumentation: Ideal for converting gauge readings from imperial to metric units in low-pressure systems.
- Industrial Applications: Useful in various industries requiring pressure conversions between these units for process control and monitoring.
This calculator is a practical tool for engineers, technicians, and professionals working in fields that demand precise pressure conversions.
