Psi to Standard Atmospheric Pressure (atm) Conversion Calculator
The below simple tool for converting pressure from pounds per square inch (psi) to standard atmospheric pressure (atm):
The standard atmosphere (symbol: atm) is a unit of pressure defined as 101,325 pascals (Pa). It is approximately equal to the average atmospheric pressure at sea level on Earth.
Suppose you have a pressure of 50 psi.
To convert it to atm:
50×0.068046=3.4023 atm
So, 50 psi is equal to 3.4023 atm.
Psi (pound-force per square inch)Standard Atmosphere (atm)
1 psi0.068046 atm
5 psi0.34023 atm
10 psi0.68046 atm
20 psi1.36092 atm
50 psi3.4023 atm
100 psi6.8046 atm
200 psi13.6092 atm
500 psi34.023 atm
1000 psi68.046 atm
  • Engineering Applications: Convert pressures in pneumatics, HVAC, and other systems.
  • Instrumentation: For converting gauge readings from imperial units to metric units.
This calculator can be useful for engineers, technicians, and anyone working in fields where accurate pressure measurement and conversions are essential.
