Psi to KPa Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from converting pounds per square inch (psi) to kilopascals (kPa):
A kilopascal (symbol: kPa) is a unit of pressure in the metric system. It is equal to 1,000 pascals. The kilopascal is commonly used in engineering and various other fields to measure pressure.
Suppose you have a pressure of 50 psi.
  • To convert it to kPa: 50 × 6.894757 = 344.73785 kPa
  • So, 50 psi is equal to 344.73785 kPa.
Here’s a quick reference table for common psi values to kPa:
Psi (pound-force per square inch)kPa (kilopascal)
0.1 psi0.6894757 kPa
1 psi6.894757 kPa
2 psi13.789514 kPa
5 psi34.473786 kPa
10 psi68.947572 kPa
20 psi137.895144 kPa
50 psi344.73785 kPa
100 psi689.4757 kPa
500 psi3447.3785 kPa
1000 psi6894.757 kPa
  • Engineering Applications: Convert pressures used in pneumatic, hydraulic, and structural systems.
  • Instrumentation: For converting gauge readings from imperial units to metric units.
This conversion calculator is useful in fields where accurate pressure measurement is crucial, such as fluid dynamics, mechanical engineering, and meteorology
