Pounds per Square Inch (psi) to Pounds per Square Foot (psf) Pressure Unit Conversion Calculator
This calculator allows you to quickly convert pressure values from Pounds per Square Inch (psi) to Pounds per Square Foot (psf), a useful conversion in engineering, construction, and various industrial applications.
Pounds per Square Inch (psi) is a unit of pressure measuring the force exerted over one square inch of area. It is widely used in mechanical engineering, hydraulics, and pneumatic systems.
Pounds per Square Foot (psf) is a unit of pressure representing the force applied per square foot of area. This unit is often utilized in civil engineering, construction, and material testing.
(since there are 144 square inches in a square foot)
Suppose you have a pressure of 5 psi. To convert it to psf:
5 psi×144=720 psf
So, 5 psi is equal to 720 psf.
Pounds per Square Inch (psi)Pounds per Square Foot (psf)
1 psi144 psf
5 psi720 psf
10 psi1440 psf
50 psi7200 psf
100 psi14400 psf
  • Construction and Civil Engineering: Helpful for converting psi measurements to psf for structural load and stress analysis.
  • Mechanical Engineering: Essential for systems where pressure needs to be standardized in psf but is measured in psi.
  • Hydraulics and Pneumatics: Useful in settings where psi measurements are converted for compatibility with psf-based specifications.
  • Industrial Calibration: Important for calibration tasks where pressure is converted between psi and psf.
This psi to psf conversion calculator is a valuable tool for professionals in engineering, construction, and industrial sectors that require precise pressure conversions.
