Pounds per Square Inch (psi) to Inch of Mercury (inHg) Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from Pounds per Square Inch (psi) to Inch of Mercury (inHg), commonly used in weather forecasting, aviation, and industrial applications requiring precise pressure measurements.
Pounds per Square Inch (psi) is a unit of pressure in the imperial system that measures the pressure resulting from a force of one pound-force applied to an area of one square inch. It is commonly used in applications like hydraulics, automotive systems, and pipeline pressures.
The Inch of Mercury (inHg) is a unit of pressure based on the pressure exerted by a 1-inch column of mercury at 0°C under standard gravity. It is frequently used in barometric pressure measurements, weather reports, and various industrial applications.
Suppose you have a pressure of 10 psi. To convert it to inHg:
10?psi×2.03602=20.3602?inHg10
So, 10 psi is approximately equal to 20.36 inHg.
Pounds per Square Inch (psi)Inch of Mercury (inHg)
1 psi2.03602 inHg
5 psi10.1801 inHg
10 psi20.3602 inHg
15 psi30.5403 inHg
30 psi61.0806 inHg
50 psi101.801 inHg
  • Weather Forecasting: Useful for converting pressure readings in psi to inHg for barometric measurements.
  • Aviation: Important for altimeter calibrations and other pressure-sensitive instruments in aircraft.
  • Industrial Applications: Used in systems where psi is the standard, but conversion to inHg is necessary for consistency.
  • Automotive Applications: Useful for measuring and comparing pressure in engines, tires, and fluid systems.
This psi to inHg conversion calculator is an essential tool for professionals in meteorology, aviation, and various engineering fields requiring accurate and reliable pressure conversions.
