Origin of instrumentation.
Developments in Instrumentation Engineering
The origins of instrumentation can be traced back to ancient times when early civilizations used basic instruments to measure time, distance, and weight. For example, the ancient Egyptians used a simple water clock to measure time, while the Greeks developed the first odometer to measure distance.
The development of modern instrumentation, however, can be traced back to the Industrial Revolution of the 18th and 19th centuries. With the growth of industry and the need for more efficient production processes, engineers began to develop more sophisticated instruments to measure and control various parameters.
One of the earliest examples of modern instrumentation was the steam engine governor, developed by James Watt in the late 18th century. This device used a centrifugal governor to regulate the speed of the steam engine, allowing it to operate more efficiently.
During the 19th century, advances in electrical engineering led to the development of electrical instruments for measuring voltage, current, and resistance. In the early 20th century, the invention of the vacuum tube led to the development of electronic instruments, such as oscilloscopes and signal generators.
Since then, instrumentation has continued to evolve and advance with the development of new technologies such as microprocessors, digital signal processing, and wireless communication. Today, instrumentation plays a critical role in a wide range of industries, from manufacturing and energy production to healthcare and environmental monitoring.
Evolution of Instrumentation Engineering
Here is an overview of some of the major developments in measurement technology in instrumentation engineering by decade:
1900s-1910s
  • Development of galvanometers for measuring small electrical currents.
  • Introduction of photoelectric cells for measuring light intensity.
1920s-1930s
  • Development of cathode ray oscilloscopes for visualizing electrical signals.
  • Invention of the thermocouple for measuring temperature.
1940s-1950s
  • Introduction of strain gauges for measuring mechanical strain.
  • Development of capacitive sensors for measuring distance and displacement.
1960s-1970s
  • Invention of the first solid-state pressure sensors.
  • Introduction of laser interferometry for high-precision measurements of distance and displacement.
1980s-1990s
  • Development of digital signal processing techniques for improving the accuracy and resolution of measurements.
  • Introduction of fiber optic sensors for measuring temperature, pressure, and other parameters.
2000s-2010s
  • Development of MEMS (Micro-Electro-Mechanical Systems) sensors for measuring acceleration, pressure, and other parameters in small and portable devices.
  • Introduction of high-speed and high-resolution cameras for visualizing and measuring motion and deformation.
  • Advancements in nanotechnology for measuring small-scale phenomena such as single-molecule interactions.
Overall, measurement technology in instrumentation engineering has undergone significant advancements and innovations over the past century, leading to more accurate, precise, and versatile measurement devices and techniques. These advancements have enabled breakthroughs in various fields, from aerospace and automotive engineering to biomedicine and environmental science.
Implementation of Instrumentation
Instrumentation is implemented in either in Simple/ Stand alone or in Complex System. Example of Simple system is tachometer and example of Complex system is crude oil Heating process
Complex instrumentation system
