MODBUS Protocol Quiz :Test Your Knowledge
Test your MODBUS protocol knowledge with this comprehensive quiz designed for automation professionals. This quiz covers key aspects of MODBUS, including function codes, error-checking methods, and communication modes.
Test Your Knowledge: MODBUS Protocol Quiz
What role does a MODBUS gateway play?
What is the primary advantage of using MODBUS over TCP/IP compared to MODBUS RTU?
How is floating-point data typically represented in MODBUS?
Which of the following statements is true about MODBUS Exception Codes?
What type of devices can act as a MODBUS master?
How is data transmitted in MODBUS TCP/IP?
In a MODBUS message, what follows the function code?
What is the function code for reading holding registers?
What does the term ‘PDU’ stand for in MODBUS communication?
Which function code is used to write multiple registers in MODBUS?
What is the primary difference between MODBUS RTU and MODBUS ASCII?
Which of the following is true about MODBUS over serial communication?
In MODBUS communication, what does the term ‘coil’ refer to?
Which of the following is NOT a valid MODBUS function code?
How many bits are in a MODBUS RTU byte?
What is the maximum number of coils that can be read in a single MODBUS request?
Which MODBUS function code is used to read input registers?
What is the purpose of a Unit Identifier in MODBUS TCP/IP?
In MODBUS ASCII mode, what character marks the start of a frame?
Which MODBUS function code is used to write a single coil?
What type of error-checking does MODBUS RTU use?
Which of the following MODBUS function codes is used to read discrete inputs?
In MODBUS RTU mode, how is the end of a message frame determined?
What is the default port number for MODBUS TCP/IP?
Which layer of the OSI model does the MODBUS protocol primarily operate on?
The average score is 62%
Click here for Instrumentation Question
