Millimeter of Water Column (mmWC) to Pascal (Pa) Pressure Unit Conversion Calculator
This calculator enables seamless conversion of pressure values from Millimeter of Water Column (mmWC) to Pascal (Pa), widely used in engineering, environmental sciences, and industrial calibration applications requiring precise pressure measurements.
The Millimeter of Water Column (mmWC) is a unit of pressure defined as the pressure exerted by a 1 mm high water column at 4°C (standard temperature) under standard gravity. It is commonly used in HVAC systems, fluid mechanics, and water level measurements.
The Pascal (Pa) is the SI unit of pressure, defined as one Newton per square meter (N/m²). It is the standard unit for pressure measurement in scientific and industrial applications.
Suppose you have a pressure of 50 mmWC. To convert it to Pa:
50 mmWC×9.80665=490.3325 Pa
Thus, 50 mmWC is equal to approximately 490.33 Pa.
Millimeter of Water Column (mmWC)Pascal (Pa)
1 mmWC9.80665 Pa
10 mmWC98.0665 Pa
50 mmWC490.3325 Pa
100 mmWC980.665 Pa
500 mmWC4903.325 Pa
1000 mmWC9806.65 Pa
  • HVAC Applications: For airflow and pressure drop measurements.
  • Industrial Calibration: Vital for process instrumentation and control systems.
  • Fluid Mechanics: Commonly used in water column pressure calculations.
  • Environmental Studies: Helpful in hydrology and meteorological research.
This mmWC to Pa conversion calculator is a must-have tool for professionals working in fields requiring precise pressure unit conversions.
Here you can refer more 200+Online Instrumentation Calculators Collections
