Millimeter of Water Column (mmWC) to Kilopascal (kPa) Pressure Unit Conversion Calculator
This calculator helps you easily convert pressure values from Millimeter of Water Column (mmWC) to Kilopascal (kPa), a widely used pressure unit in industrial, scientific, and engineering applications.
The Millimeter of Water Column (mmWC) is a unit of pressure that represents the pressure exerted by a 1-millimeter-high column of water. It is commonly used in low-pressure systems like HVAC, water distribution, and other applications requiring precise pressure control.
The Kilopascal (kPa) is a metric unit of pressure, where 1 kPa equals 1000 Pascals (Pa). It is commonly used in a wide range of industries, including engineering, meteorology, and construction, to measure both low and high pressures.
Suppose you have a pressure of 500 mmWC.
To convert it to kPa:
500×0.00980665=4.9033?kPa
So, 500 mmWC is equal to 4.9033 kPa.
Millimeter of Water Column (mmWC)Kilopascal (kPa)
100 mmWC0.98067 kPa
200 mmWC1.9613 kPa
500 mmWC4.9033 kPa
1000 mmWC9.8067 kPa
2000 mmWC19.61 kPa
  • HVAC and Water Systems: Convert low-pressure mmWC readings to kPa for precise system monitoring.
  • Industrial and Scientific Applications: Ideal for converting pressure values in instrumentation, laboratory work, and low-pressure control systems.
  • Engineering and Environmental Monitoring: Useful for converting water column pressure values to kPa in structural engineering and environmental applications.
This mmWC to kPa conversion calculator is essential for professionals working in industries where low-pressure measurements are common and require accurate conversions.
