Millimeter of Mercury (mmHg) to Torr Pressure Unit Conversion Calculator
This calculator allows you to easily convert pressure values from Millimeter of Mercury (mmHg) to Torr, commonly used in scientific research, vacuum measurements, and various engineering applications that require accurate pressure conversions.
The Millimeter of Mercury (mmHg) is a unit of pressure that represents the force exerted by a 1-millimeter column of mercury at 0°C under standard gravity. It is frequently used in barometry, medical applications, and vacuum systems.
The Torr is a unit of pressure, defined as exactly 1/760 of an atmosphere. It is equivalent to the Millimeter of Mercury and is widely used in fields like physics, chemistry, and engineering, especially in vacuum measurements.
Since 1 mmHg is equivalent to 1 Torr, the conversion is direct and straightforward.
Suppose you have a pressure of 500 mmHg.
To convert it to Torr:
500×1=500 Torr
So, 500 mmHg is equal to 500 Torr.
Millimeter of Mercury (mmHg)Torr
1 mmHg1 Torr
10 mmHg10 Torr
100 mmHg100 Torr
500 mmHg500 Torr
760 mmHg760 Torr
1000 mmHg1000 Torr
  • Vacuum Measurements: Essential for converting pressure values in scientific research and vacuum systems.
  • Scientific Research: Useful in laboratory settings that use both mmHg and Torr units.
  • Industrial Applications: Applicable for precision control and calibration tasks where mmHg and Torr are both utilized.
  • Medical Applications: Frequently used in applications such as respiratory therapy and blood pressure monitoring.
This mmHg to Torr conversion calculator is a handy tool for professionals in scientific, medical, and industrial fields that require accurate pressure conversions.
