Megapascal (MPa) to Psi Pressure Unit Conversion Calculator
This calculator allows you to quickly and accurately convert pressure values from Megapascal (MPa) to Psi (Pounds per Square Inch), ideal for engineering, scientific, and industrial applications.
A Megapascal (MPa) is a metric unit of pressure, equivalent to 1 million Pascals (Pa). It is used in high-pressure systems across industries like engineering, construction, and material testing.
Psi is an Imperial unit of pressure that measures the force exerted over a square inch of surface area. It is widely used in various applications such as hydraulics, pneumatics, and tire pressure.
Suppose you have a pressure of 2 MPa.
To convert it to Psi:
2×145.038=290.076 Psi
So, 2 MPa is equal to approximately 290.076 Psi.
MPaPsi
0.1 MPa14.5038 Psi
0.5 MPa72.519 Psi
1 MPa145.038 Psi
2 MPa290.076 Psi
5 MPa725.19 Psi
10 MPa1,450.38 Psi
  • Hydraulics and Pneumatics: Convert high-pressure MPa readings to Psi for system designs and maintenance.
  • Engineering and Construction: Useful in converting pressure values for load analysis, structural calculations, and material strength testing.
  • Industrial Applications: Ideal for converting MPa to Psi in high-pressure equipment and process control systems.
This MPa to Psi conversion calculator is a valuable tool for engineers, technicians, and professionals working in fields requiring accurate pressure unit conversions.
