Mass Flow Unit Conversion Calculator: Kilograms per Hour (kg/h) to Metric Tons per Hour (t/h)
Engineers and process experts may precisely convert Kilograms per Hour (kg/h) to Metric Tons per Hour (t/h) with the Flow Unit Conversion Calculator. In sectors including mining, food processing, bulk material handling, and chemical manufacture, where precise flow measurements are essential for inventory keeping, production planning, and control system design, mass flow conversions are important.
A metric unit of mass flow rate, kilograms per hour (kg/h) shows how many kilograms of material pass through a point or system in one hour. Process engineering, agriculture, material handling, and bulk processing processes all frequently use this unit.
  • Tracking feedstock or additive flows in ongoing production lines.
  • Calculating the mass flow of bulk liquids or solids in dosing and batching processes.
  • Tracking raw material use in pharmaceutical, beverage, and food industries.
  • Assessing biomass, fuel, or sludge flow in waste-to-energy facilities.
High-volume mass flow is expressed using the larger-scale unit Metric Tons per Hour (t/h). This measure is perfect for heavy-duty industrial operations and large-scale material transfer since one metric ton (also known as a tonne) is 1,000 kg.
  • Mining’s conveyors and feeders are examples of bulk solids handling equipment.
  • Logistics and shipping high-volume loading and unloading activities.
  • Flow metering in aggregate industries, refineries, or cement plants.
  • Performance evaluation in process plants handling mass-intensive products.
Use the following conversion formula:
Because 1 metric ton = 1,000 kilograms, dividing the flow rate in kg/h by 1,000 gives the equivalent in metric tons per hour.
If a process delivers 7,500 kg/h of material, to convert to metric tons per hour:
7,500 kg/h ÷ 1,000 = 7.5 t/h
So, a mass flow of 7,500 kg/h is equal to 7.5 t/h.
Kilograms per Hour (kg/h)Metric Tons per Hour (t/h)
1,000 kg/h1 t/h
5,000 kg/h5 t/h
7,500 kg/h7.5 t/h
10,000 kg/h10 t/h
20,000 kg/h20 t/h
50,000 kg/h50 t/h
100,000 kg/h100 t/h
  • Aligns manufacturing data with supply chain goals and real-time control panels.
  • Guarantees correct setup of automation systems, mass flow controllers, and flow meters.
  • Allows correct data reporting to regulatory authorities in either metric or SI units.
  • International Projects: Uses both detailed (kg/h) and bulk (t/h) units to help integrate worldwide operations.
  • Design Engineering: Helps engineers choose equipment depending on material throughput rates.
Process engineers, system designers, plant operators, and maintenance teams will find the Flow Unit Conversion Calculator to be a great tool since it guarantees consistent and precise mass flow reporting across systems.
