Mass Flow Rate Conversion: Kilograms per Second (kg/s) to Pounds per Second (lb/s) Flow Unit Conversion Calculator
Engineers and process experts can convert Kilograms per Second (kg/s) to Pounds per Second (lb/s) with the Mass Flow Rate Conversion Calculator. Accurate mass flow measurements significantly influence process performance and equipment calibration in several sectors, including chemical processing, power generation, and oil & gas, making this conversion essential.
A metric measurement called kilograms per second (kg/s) measures the mass flow rate of a substance the amount of mass flowing through a spot per unit of time. Scientific, industrial, and engineering applications all make great use of this unit.
  • Calculating rates of fuel and air flow in engines and combustion systems.
  • Calculating power plant feedwater and steam flow.
  • Applied to mixing operations and dosing systems in industrial process control.
  • Frequent in computational fluid dynamics(CFD) investigations and simulation models.
Often seen in American engineering systems, pounds per second (lb/s) is an imperial (U.S. customary) unit of mass flow rate. It is the mass in pounds moving per second through a system.
  • Mass flow measurements in mechanical and aerospace systems in the U.S.
  • Calculations of steam and boilers in traditional thermal power facilities.
  • Monitoring of fuel flow in jet engines and gas turbines.
  • Measurement in refrigeration and HVAC systems built using imperial units.
The formula below will help you to go from Kilograms per Second (kg/s) to Pounds per Second (lb/s):
The factor 2.20462 represents the number of pounds in one kilogram.
You have a process where the flow rate is measured at 5 kg/s.
To convert it to pounds per second:
5 kg/s × 2.20462 = 11.0231 lb/s
So, a flow rate of 5 kg/s is equivalent to approximately 11.02 lb/s.
Kilograms per Second (kg/s)Pounds per Second (lb/s)
1 kg/s2.20462 lb/s
5 kg/s11.0231 lb/s
10 kg/s22.0462 lb/s
20 kg/s44.0924 lb/s
50 kg/s110.231 lb/s
100 kg/s220.462 lb/s
200 kg/s440.924 lb/s
  • compatibility while operating across foreign sites employing various measuring systems.
  • Based on needed units, control system configuration helps to properly configure PID loops and flow transmitters.
  • System Design: Aids in the creation of flow-based metering systems, combustion chambers, and heat exchangers.
  • Regulatory reporting in areas employing either SI or imperial units is aided by Compliance & Reporting.
  • Helps data transfer between metric-based and imperial-based software and instrumentation systems.
A valuable tool for chemical engineers, aerospace experts, plant operators, and system designers, the conversion calculator allows fast and accurate conversions to simplify operations and improve cross-border technical integration.
