Liters per Minute (L/min) to Cubic Meters per Hour (m³/h) Flow Unit Conversion Calculator
Users can transfer their measurement data from Liters per Minute (L/min) to the common standard of Cubic Meters per Hour (m³/h) using this tool. The conversion enables multiple industrial functions to maximize their efficiency because it enhances fluid transport systems and water management infrastructure as well as industrial processes.
The industry standard metric used to evaluate flow rates of liquids and gases measures volume transportation through the unit of Liters per Minute (L/min).
  • The measurement of fluid flow takes place in hydraulic systems with this unit.
  • Water supply rates are typically measured through the use of this unit in water distribution systems.
  • The process and chemical industries make use of this unit to control material distribution.
  • The flow rate of refrigerants throughout HVAC and cooling systems requires this measurement.
Large-scale fluid flow rates are measured by applying the cubic meters per hour metric unit (m³/h). This universal flow measurement unit exists throughout the industrial sector as well as municipal water treatment systems and oil and gas transport processes.
  • Measurement of large-scale industrial liquid and gas flow.
  • Productivity measurement systems apply m³/h for examining pipeline capacity levels and transporting fluids.
  • Essential in municipal and commercial water distribution systems.
  • Wastewater treatment facilities and irrigation systems use this phenomenon for operations.
To achieve the conversion between Liters per Minute (L/min) and Cubic Meters per Hour (m³/h) utilize this formula:
The conversion between L/min values and m³/h values requires a multiplication factor of 0.06 because 1 liter per minute equals 0.06 cubic meters per hour.
 If your current flow rate is 500 L/min, convert it to m³/h:
500 L/min × 0.06 = 30 m³/h
Thus, a flow rate of 500 L/min is equivalent to 30 m³/h.
Liters per Minute (L/min)Cubic Meters per Hour (m³/h)
1 L/min0.06 m³/h
10 L/min0.6 m³/h
50 L/min3 m³/h
100 L/min6 m³/h
500 L/min30 m³/h
1,000 L/min60 m³/h
5,000 L/min300 m³/h
10,000 L/min600 m³/h
  • Industrial professionals use conversion to monitor both water and chemical operations during processing flows.
  • The evaluation of cooling and heating system fluid transport functions is performed by engineers utilizing this metric.
  • Municipal water treatment facilities implement this conversion as the key element for large-scale distribution operations.
  • The sizing of hydraulic system components depends on flow rate calculations performed by designers.
  • Exact conversion in the oil and gas industry allows engineers to perform proper pipeline designs and operational activities.
  • Process control and automation institutions use this measurement to improve their operational performance.
The precise flow rate calculation capabilities of this conversion tool benefit engineers and hydrologists and industrial fluid management professionals who need improved operational efficiency in multiple industries.
