Kilopascal (kPa) to Standard Atmospheric Pressure (atm) Conversion Calculator
This calculator allows you to quickly convert pressure values from Kilopascal (kPa) to Standard Atmospheric Pressure (atm), perfect for engineering, scientific, and industrial applications.
The Kilopascal (kPa) is a metric unit of pressure equivalent to 1,000 Pascals (Pa). It is widely used in a variety of industries, including engineering, HVAC, and material testing.
The Standard Atmosphere (atm) is a pressure unit defined as 101,325 Pascals (Pa), representing the average atmospheric pressure at sea level.
Suppose you have a pressure of 200 kPa.
To convert it to atm:
200 ÷ 101.325=1.974 atm
So, 200 kPa is equal to approximately 1.974 atm.
kPaatm
10 kPa0.0987 atm
50 kPa0.493 atm
100 kPa0.9869 atm
101.325 kPa1 atm
200 kPa1.974 atm
500 kPa4.934 atm
  • Engineering and HVAC Systems: Convert kPa to atm for accurate system design, pressure monitoring, and maintenance.
  • Industrial Applications: Useful for converting high-pressure values in manufacturing and process control environments.
  • Scientific Research: Provides precise pressure conversions for laboratory experiments that require atmospheric pressure values.
This kPa to atm conversion calculator is a helpful tool for professionals needing fast and accurate pressure unit conversions.
