Inch of Water (inH2O) to Psi Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from inches of water (inH2O) to pounds per square inch (psi).
An inch of water (symbol: inH2O) is a unit of pressure. It represents the pressure exerted by a column of water one inch high at 39.2°F under standard gravity. This unit is commonly used in various industries, including HVAC, to measure differential pressure.
Suppose you have a pressure of 10 inH2O.
 To convert it to psi: 10 × 0.0361273 = 0.361273 psi
 So, 10 inH2O is equal to 0.361273 psi.
Inch of Water (inH2O)Psi (pound-force per square inch)
1 inH2O0.0361273 psi
5 inH2O0.1806365 psi
10 inH2O0.361273 psi
20 inH2O0.722546 psi
50 inH2O1.806365 psi
100 inH2O3.61273 psi
200 inH2O7.22546 psi
500 inH2O18.06365 psi
1000 inH2O36.1273 psi
  • HVAC Systems: Convert pressures in ductwork and other HVAC systems from inH2O to psi.
  • Instrumentation: Useful for converting gauge readings in water-based systems to psi.
  • Industrial Applications: Applicable in various industries where pressure measurements in different units are required.
This calculator is a valuable tool for engineers, technicians, and professionals working in fields that require accurate pressure conversions between these units.
