This calculator allows you to convert pressure values from Inches of Water (inH?O) to Millimeters of Mercury (mmHg), a commonly required conversion in HVAC, fluid dynamics, and various scientific applications.
Definition: Inch of Water (inH?O)
The Inch of Water (inH?O) is a unit of pressure that represents the pressure exerted by a 1-inch column of water at 4°C. This unit is often used in HVAC systems, water column measurements, and low-pressure environments.
Definition: Millimeter of Mercury (mmHg)
The Millimeter of Mercury (mmHg) is a unit of pressure representing the force exerted by a 1-millimeter column of mercury at 0°C under standard gravity. It is frequently used in barometric readings, medical applications, and vacuum systems.
Formula for inH?O to mmHg Conversion:
Pressure in mmHg=Pressure in inH?O×0.0735559
How to Convert inH?O to mmHg: Example Calculation
Suppose you have a pressure of 10 inH?O. To convert it to mmHg:
10 inH?O×0.0735559=0.735559 mmHg
So, 10 inH?O is equal to approximately 0.7356 mmHg.
Quick Reference Conversion Table for inH?O to mmHg
Inch of Water (inH?O) | Millimeter of Mercury (mmHg) |
1 inH?O | 0.07356 mmHg |
5 inH?O | 0.36778 mmHg |
10 inH?O | 0.73556 mmHg |
20 inH?O | 1.47112 mmHg |
100 inH?O | 7.35559 mmHg |
Uses of inH?O to mmHg Conversion Calculator:
- HVAC Systems: Common for measuring air pressure differentials in ventilation systems.
- Scientific Research: Helpful for converting low-pressure measurements from inH?O to mmHg.
- Fluid Dynamics: Essential for applications in water column measurement and low-pressure scenarios.
- Medical Applications: Useful in settings where both inH?O and mmHg measurements are needed for precision.
This inH?O to mmHg conversion calculator is an essential tool for professionals in HVAC, scientific research, fluid dynamics, and medical fields requiring accurate pressure conversions.
