Engineers, technicians, and system designers can use the SCFM to SLPM Conversion Calculator to accurately change gas flow measurements from Standard Cubic Feet per Minute (SCFM) to Standard Liters per Minute (SLPM). In fields like HVAC, semiconductor manufacturing, environmental monitoring, and process automation, this conversion is very important since it makes sure that all unit systems are the same, which is necessary for proper design, performance analysis, and compliance with regulations.
Definition: Standard Cubic Feet per Minute (SCFM)
SCFM is a standard unit of measurement for gas flow in the U.S. It tells you how much gas flows in a minute under normal conditions, which are usually 14.7 psia (1 atm), 68–70°F (20–21.1°C), and 0% relative humidity. It is often used to size compressors, specify pneumatic tools, and design industrial air systems.
Key Applications of SCFM:
- Sizing air compressors, blowers, and vacuum pumps.
- Setting the amount of air flow in cleanrooms and HVAC systems.
- Keeping an eye on how much compressed air is used in manufacturing.
- Checking how well the gas supply works for pneumatic equipment and actuators.
Definition: Standard Liters per Minute (SLPM)
Standard Liters per Minute (SLPM) is a metric measurement that measures gas flow under normal conditions, which are usually 0°C or 20°C and 1 atm. It tells you how many liters of gas go past a measurement location every minute. It is often used in science, labs, and global industry.
Key Applications of SLPM:
- Mostly used for calibrating flow sensors and gas analyzers in labs.
- Dosing gases in the semiconductor, food, and drug sectors.
- Keeping an eye on gas flows in scrubbers and venting systems.
- Controlling the flow of shielding gas in welding jobs.
Formula for SCFM to SLPM Conversion
To convert SCFM to SLPM, use the following formula:
Flow in SLPM=Flow in SCFM×28.3168
Because 1 SCFM = 28.3168 SLPM, multiplying the SCFM value by 28.3168 gives the equivalent in SLPM.
Example Calculation
If a blower delivers 12 SCFM of air, to convert it into SLPM:
12 SCFM×28.3168=339.80 SLPM12
So, a flow rate of 12 SCFM is equal to approximately 339.80 SLPM.
Standard Cubic Feet per Minute (SCFM) | Standard Liters per Minute (SLPM) |
1 SCFM | 28.32 SLPM |
5 SCFM | 141.58 SLPM |
10 SCFM | 283.17 SLPM |
12 SCFM | 339.80 SLPM |
20 SCFM | 566.34 SLPM |
50 SCFM | 1,415.84 SLPM |
100 SCFM | 2,831.68 SLPM |
Uses of SCFM to SLPM Conversion
- Global Projects: Makes it easy to combine data from different systems using U.S. customary and SI units.
- Instrument Selection: Helps make sure that gas flow meters and regulators meet international standards.
- Regulatory Compliance: Makes ensuring that units follow the rules for reporting and documentation in their area.
- System Optimization: Helps you keep an eye on and operate industrial gas handling systems with great accuracy.
- Energy Audits: Helps keep track of how much compressed air and inert gas are used to keep operations running smoothly.
HVAC designers, process engineers, automation specialists, and maintenance workers who work with gas flow systems in both metric and international settings use this calculator as a reference tool.
