Gas Flow Rate Conversion Calculator: Standard Cubic Feet per Minute (SCFM) to Normal Cubic Meters per Hour (Nm³/h)
Working across U.S. conventional and metric systems, engineers, plant operators, and fluid mechanics experts often find themselves converting Standard Cubic Feet per Minute (SCFM) to Normal Cubic Meters per Hour (Nm³/h). Accurate modeling, system sizing, compliance reporting, and multinational project cooperation all depend on this conversion.
Measured at standard conditions usually 14.7 psi (1 atm), 68°F (20°C), and dry air SCFM is a unit of volumetric gas flow. In the United States, it is commonly used for industrial equipment, gas processing, and air systems.
  • Sizing of pneumatic tools and air compressors
  • Gas flow measurement in industrial systems and pipelines
  • Monitoring of HVAC system ventilation
  • Flow instrument calibration in U.S.-based facilities
The metric unit measuring gas flow at standardized circumstances, usually 1 atm and 0°C (273.15 K), is Nm³/h. Scientific, engineering, and multinational industrial uses all make great use of it.
  • Gas metering in energy, medicinal, and chemical plants
  • Combining SCADA, DCS, and PLC control systems
  • SI-based process simulation utilizing tools such as MATLAB, Aspen, or COMSOL
  • Uniform reporting for emissions, flow audits, and compliance
The following formula will help you to convert Standard Cubic Feet per Minute (SCFM) to Normal Cubic Meters per Hour (Nm³/h):
Assuming optimal gas behavior, the conversion factor 1.699 compensates for gas volume under standard international conditions.
If a system delivers 120 SCFM, then:
120 SCFM × 1.699 = 203.88 Nm³/h
So, a gas flow rate of 120 SCFM is equal to 203.88 Nm³/h.
SCFMNm³/h
11.699
58.495
1016.99
2033.98
5084.95
100169.90
250424.75
500849.50
10001699.00
  • International Cooperation: Allows regular data transfer between imperial and metric systems
  • Process Modeling: Reduces metric-based simulation tool input
  • Instrumentation Calibration: Compares SI-based flowmeters and controls to SCFM data
  • Changes flow rates to metric values needed for compliance papers.
  • System Design: Aids in precise gas flow sizing in pipelines, blowers, and compressors
  • HVAC and ventilation engineers operating under U.S. and foreign criteria
  • Mixed-unit equipment users among instrumentation experts
  • Process control engineers creating SI-compatible controllers and models
  • Project engineers in charge of worldwide environmental, chemical, or energy systems
  • Technical advisors conducting energy or emissions audits
Here you can refer more 200+Online Instrumentation Calculators.
