Effect of Tank Design on Accuracy of Level Measurement
In many industrial applications and processes, including as manufacturing, chemical processing, oil and gas, water treatment, and others, level measuring is a crucial component. In order to monitor processes, manage inventories, and ensure secure and effective operations, level readings must be accurate.
The tank’s design has a big impact on the accuracy and reliability of level measurements. Let’s examine each of the key elements in greater detail:
Effect of Tank Design on Accuracy of Level Measurement 1
Tank Shape and Geometry
  • Tanks come in different shapes and geometries, such as cylindrical, spherical, rectangular, or irregular.
  • Cylindrical tanks are commonly used due to their simple design, providing consistent and predictable level measurements.
  • Irregular shapes or complex geometries may introduce measurement errors due to uneven distribution of contents, leading to variations in measurements.
Tank Size and Height
  • The size and height of the tank can affect the accuracy of level measurement.
  • Due to the relative greater influence of sensor tolerances, readings of smaller tanks may have higher percentage errors.
  • Taller tanks can introduce hydrostatic pressure variations, impacting measurement accuracy and requiring compensation for pressure effects.
Construction Material
  • The tank’s material can affect the accuracy of level measuring.
  • Non-metallic or non-conductive materials, for example, can have an impact on the performance of level measurement technologies such as capacitance or conductive sensors.
  • Due to electromagnetic phenomenon, metal tanks may cause signal interference for several non-contact level measuring devices.
Tank Wall Thickness
  • The thickness of the tank walls can impact level measurement accuracy.
  • Thick walls can reduce signal penetration for certain technologies, leading to less precise measurements.
  • For ultrasonic or radar-based measurements, thick walls may also introduce reflections and echoes that affect the accuracy of readings.
Effects of Sloshing and Waves
  • The presence of sloshing and waves in the tank can result in measurement errors.
  • These effects can be most noticeable in tanks containing free surface liquids, such as gasoline tanks on moving vehicles or ships.
  • In such instances, specific strategies or technologies may be necessary to adjust for sloshing effects.
Pressure and temperature
  • To achieve accurate level measurements, tank design should take temperature and pressure variations into account.
  • Temperature changes might cause the liquid to expand or contract, affecting the observed level.
  • Thermal influences might cause the tank to expand or contract. This can have a big influence on level-based measurements instead of volume measurements since an extended tank might have more fuel in it at a certain midpoint than it would have at the same midpoint without expansion.
  • High-pressure conditions can have an impact on the performance of some measurement devices, requiring pressure corrections.
Properties of Liquids
  • The physical qualities of the liquid being measured can have an impact on the accuracy of the level measurement.
  • Certain level measurement devices may be hampered by liquids with high viscosity or low dielectric constants.
  • Proper measuring equipment selection can account for these qualities and provide reliable measurements.
  • The expansion of the shell caused on by the substance contained
Fumes and Vapors
  • Tanks containing volatile liquids can emit vapors and fumes that can interfere with certain level measurement systems, such as ultrasonic or optical sensors.
  • To ensure measurement accuracy, proper ventilation or the use of vapor-resistant sensors may be required.
Calibration and Sensor Positioning
  • Accurate level measurements require proper calibration and sensor positioning.
  • Calibration ensures that the readings correlate to the liquid’s real level.
  • To avoid incorrect readings, sensor placement should take into account the tank’s internal features as well as potential obstacles.
Agitators and Baffles
  • Tanks containing baffles and agitators might have an impact on level measuring accuracy.
  • Wave reflections caused by baffles can result in misleading level measurements during measuring.
  • Agitators can cause disturbances on the liquid surface, altering its stability and introducing measuring inaccuracies.
Maintenance and Human Error
  • Human error during tank installation or maintenance can result in inaccurate level measurement.
  • To maintain sustained accuracy, regular maintenance and calibration checks are required.
  • Human errors can be reduced by properly training workers involved in tank operations and level measurement.
Environmental Aspects
  • External environmental conditions can have an impact on the accuracy of level measurement.
  • Sensor performance can be impacted by vibrations, electromagnetic interference, and temperature variations.
  • Sensor shielding or isolation may be required in settings with severe electromagnetic interference.
Technology for Level Measurement
  • The level measurement system selected should be compatible with the tank design and intended application.
  • Ultrasonic, radar, capacitance, and hydrostatic technologies all have variable degrees of the suitability for various tank designs.
  • Each approach has advantages and disadvantages, and the best option is determined by criteria such as tank size, contents, and environmental conditions.
Control System Integration
  • The accuracy of level measurement should be in line with the overall control system requirements.
  • Disagreements in level readings may result in inefficiencies in process control or inventory management.
  • Monitoring and communication between level sensors and control systems in real time can help to optimize operations.
Concerns Regarding Safety
  • To avoid spilling or overfilling, tank design should prioritize safety, which can affect level measuring accuracy.
  • Even in critical circumstances, proper safety procedures can assure reliable and precise measurements.
  • In the event of incorrect level readings, safety shut-off mechanisms can prevent catastrophic events.
