Definition and Need for Calibration
According to Webster’s Dictionary, calibrate means “to check, adjust, or standardize systematically the graduations of a quantitative measuring instrument.” As noted in Inter-Range Instrumentation Group (IRIG) 118-98 Volume I, “a telemetry system measurement begins with the sensing of a measurand by a transducer located either on a test vehicle or at a remote test site.It ends at a data storage or display device located at a receiving test site, radio links, direct wiring, electro-optical methods, or other combinations can interconnect telemetry systems To ensure that data is of the highest possible quality, engineers test and calibrate individual components in a suitable laboratory before installing the system. Subsequently, the engineer subjects the telemetry system to carefully conducted end-to-end calibration check just before, during, and after the current test. “This chapter provides guidance to the instrumentation engineer on how to address general calibration methodologies, techniques, and cases.The instrumentation engineer uses many types of transducers to make many physical measurements. Examples of these measurements include acceleration, velocity, displacement. pressure, acoustics, flow, strain, humidity, corrosion, images, video, temperature, heat flux, position, torque, shaft power, angular rate, time, frequency, and phase angle. Each measurement may require a different calibration technique. For example, shakers and sound generators can provide known mechanical inputs to accelerometers and microphones and to voltmeter could measure the output voltage. Inexpensive transducers may require expensive calibration techniques and procedures to ensure data validity.
Calibration Types
1. Transducer calibration which focuses on the transducer input-output outputย relationshipย
2.ย Data system calibration which simulates or models the input of the entireย measurement system
3.ย Physical end-to-end calibration
ย Physical (also called mechanical) end-to-end calibration focuses on the relationshipย between the physical input and measured output throughout the entire measurement system.
The purpose of aย measurement system is to accurately measure the state of theย unit underย test.ย The transducer converts one form of energy, such as force displacement and acceleration,ย to another form such as an electrical signal.ย The signal conditioner prepares the electrical signalย for input to a data collection device.ย The transducer usually comes with aย transfer characteristic(e.g. 100 mV/g), but the instrumentation engineer needs to know the final calibration through allย components of the signal conditioning system.The engineer sets up the signal conditioner to receive a known input type and range andย convert the signal to a standard data collection unit.ย Using information fromย the manufacturer ofย the transducer and signalย conditioner, the engineer can calculate anย output.ย However, wheneverย ย possible, the instrumentation engineer should performย an end-to-end calibration.ย Calibrationย involves applying known values to the unit under test under specified conditions and recordingย the results to improve the overall accuracy of the measurement system do this.ย Required dataย accuracy determines the need to calibrate.ย The cost of data acquisition is directly proportional toย the data accuracy.
1.Transducer calibration.ย
Usually, the transducer manufacturer performsย a unit calibrationย in their laboratory.ย The instrumentation engineer should be familiarย with the techniques used byย the manufacturer toย calibrate individual transducers.ย Experience recommends that theย engineerย ย perform an in-house calibration on the individual transducer to verify the accuracy of theย manufacturerโs transfer function.ย If there are deviations fromย the manufacturerโs transferย function, the engineer may defineย a new transfer function for thatย unit, or in some cases, reset theย device to conform to the original transfer function.ย Successive calibrations mayย indicateย upcoming failures.ย Many engineersย stop afterย performing aย transducer calibration.ย They thencombine the transducerโs transfer function mathematically with the data system signalย conditionerโs transfer functions.ย This provides a calibration estimate under the assumption thatย the engineer precisely knows all the transfer characteristics of the wiring and other signalย conditioning between the transducer andย the data storage system.ย The engineer assumes that allย wiring and signal conditioning will function as designed, but one bad connection invalidates theย data.ย Relying solely on transducer calibrationย is too risky forย collection of valid data on anย experiment or test.
2ย Data systemย calibration.ย
For making validย engineering measurements, the mostย important consideration is how the transducer operates in the actual test environment with allย signal conditioning attached.ย Although not always feasible, the transducer should be calibratedย while connected to the same signal conditioning equipment in the laboratory as will be used onย the actual test article.ย After mounting the transducer on the test article, perform a minimum of adata system calibration.ย This can be accomplished by simulating an excitation of the transducerย such as is often accomplished forย strain gages by using a shuntย calibration resistor to simulate aย change in resistance of the strain gage.ย In addition, inserting a simulated transducer signal into theย system verifiesย all signal conditioning transfer function predictions.ย This calibrationsimulates transducer excitation by its physical input.ย Installation constraints (e.g. the transducerย is inaccessible or glued onto a structure such as a strain gage) often mean that a data systemย calibration is the best that an instrumentation engineer can do to ensure acquisition of valid data.Data system calibration simulates the desired measurand rather than physically stimulating thethe transducer sensing device
3ย Physical end-to-end calibration.
ย Physical end-to-end calibration is the bestย method ofย ensuring collection of valid data.ย As stated in the Institute of Environmental Sciences andย Technology (IEST) recommended practice (RP)โ, an end-to-end mechanical calibration means aa full calibration of the instrumentation from the actual physical input to the transducer to theย output where the analog or digital signal will normally be analyzed.โย An end-to-end calibrationย verifies the measurement system characteristics.ย Engineers perform these calibrations afterย installing the measurement system in the test article.ย A calibration source stimulates theย transducer.ย The instrumentation engineer monitors the signal entering the data collectionย unit toย ensure the calculated value matches the actual systemย transfer function.ย It is highlyย recommended that an end-to-end calibration be performed before the experiment and after theย experiment is completed but before the instrumentation system is removed.ย The end-to-endย calibration checks the measurement system (including wiring,ย connectors, routing, etc) installedย on the test article, so that the engineer can identify and correct many potential problems early(including phasing and wiring errors).
4.Calibration concerns.ย
In performing calibrations,ย concerns include full scale,ย range,output signal, linearity, resolution, cross axis sensitivity, thermal zeroย shifts, thermal sensitivityย shifts, voltage offsets, hysteresis, repeatability, over range, bias errors, recording, recordย keeping, test recordings, calibrationย curves, and calibration reports.ย An instrumentation engineerย should understand if the transducer manufacturer is presenting specifications as per cent of fullย scale or percent of reading.
Also read
