Cubic Meters per Minute (m³/min) to Gallons per Minute (GPM) Flow Unit Conversion Calculator
Users can use the tool to convert measurement data in m³/min into the commonly used Gallons per Minute (GPM) unit. Improved fluid flow operations are made possible by this conversion in a number of industrial, water processing, and engineering applications.
  • used to assess high flow volumes in water distribution and treatment systems.
  • vital for controlling the flow of fluids and air in HVAC and ventilation systems.
  • used to monitor the flow rates of liquids and gases in manufacturing and industrial processes.
  • Often used to guarantee accurate control in pneumatic and hydraulic systems.
Gallons per Minute (GPM) is a common unit of measurement used to quantify the volume of liquid flow per minute, especially in the United States. It is extensively used in irrigation, firefighting, and plumbing systems.
  • used to measure water flow in plumbing systems in homes and businesses.
  • vital for controlling the distribution of water in agricultural and irrigation systems.
  • crucial for systems that distribute and transport gasoline.
  • frequently used to calculate sprinkler and hose output in fire safety systems.
  • used to track efficiency in industrial fluid processing operations.
For converting m³/min to GPM, apply the following conversion formula:
Since 1 cubic meter per minute is equivalent to approximately 264.172 gallons per minute, simply multiply the given m³/min value by 264.172 to obtain the GPM value.
If your current flow rate is 5 m³/min, convert it to GPM:
5 m³/min × 264.172 = 1,320.86 GPM
Thus, a flow rate of 5 m³/min is equivalent to 1,320.86 GPM.
Cubic Meters per Minute (m³/min)Gallons per Minute (GPM)
1 m³/min264.172 GPM
5 m³/min1,320.86 GPM
10 m³/min2,641.72 GPM
50 m³/min13,208.6 GPM
100 m³/min26,417.2 GPM
500 m³/min132,086 GPM
1,000 m³/min264,172 GPM
  • This measurement is used by engineers and technicians to assess the effectiveness of fluid transfer.
  • aids in the planning and improvement of water distribution and treatment systems.
  • vital for keeping an eye on the movement of chemicals and fuel in industrial processes.
  • helps HVAC specialists control the flow of fluids and air.
  • enables precise flow measurement for the processing and manufacturing sectors.
  • used to calculate the proper water flow for suppression systems in firefighting systems.
With the help of this conversion tool, experts in the engineering, water management, and industrial sectors may efficiently optimize their operations by calculating flow rates with accuracy and dependability.
