Users can use this tool to convert flow measurement data from Cubic Meters per Hour (m³/h) to the widely used Cubic Feet per Hour (ft³/h). This conversion is essential for professionals working across international engineering projects, HVAC systems, industrial processing, and water distribution operations.
Definition: Cubic Meters per Hour (m³/h)
Cubic Meters per Hour (m³/h) is a standard metric unit for measuring fluid or gas flow over time. It is used globally across multiple sectors to track large-scale flow volumes.
Key Applications of Cubic Meters per Hour (m³/h):
- Used in municipal and industrial water treatment and supply systems.
- Essential for measuring airflow and fluid movement in HVAC systems.
- Common in industrial chemical and process engineering applications.
- Helps monitor energy and gas transmission systems.
Definition: Cubic Feet per Hour (ft³/h)
Cubic Feet per Hour (ft³/h) is an imperial unit used primarily in the United States to measure the volume of gas or fluid passing through a system per hour. It is commonly used in utility, HVAC, and gas distribution sectors.
Key Applications of Cubic Feet per Hour (ft³/h):
- Used in U.S.-based water and gas flow monitoring systems.
- Common in HVAC and building ventilation for calculating air changes.
- Applied in utility services for tracking energy consumption in cubic feet.
- Used in natural gas distribution for metering pipeline flows.
Formula for m³/h to ft³/h Conversion
To convert m³/h to ft³/h, use the following formula:
Flow in ft³/h = Flow in m³/h × 35.3147
Since 1 cubic meter per hour equals approximately 35.3147 cubic feet per hour, multiply the m³/h value by this factor to obtain ft³/h.
Example Calculation
If your current flow rate is 100 m³/h, convert it to ft³/h:
100 m³/h × 35.3147 = 3,531.47 ft³/h
So, a flow rate of 100 m³/h is equivalent to 3,531.47 ft³/h.
Cubic Meters per Hour (m³/h) | Cubic Feet per Hour (ft³/h) |
1 m³/h | 35.3147 ft³/h |
10 m³/h | 353.15 ft³/h |
50 m³/h | 1,765.73 ft³/h |
100 m³/h | 3,531.47 ft³/h |
500 m³/h | 17,657.35 ft³/h |
1,000 m³/h | 35,314.7 ft³/h |
5,000 m³/h | 176,573.5 ft³/h |
Uses of m³/h to ft³/h Conversion
- Engineers and operators use this conversion to align metric and imperial data in cross-border projects.
- Assists in pipeline and utility system design and monitoring.
- Important for HVAC professionals working with mixed-unit systems.
- Enables utility companies to standardize data across global facilities.
- Supports energy audits and performance monitoring for large-scale systems.
This conversion tool ensures reliable and accurate flow rate conversions, empowering professionals in industrial, HVAC, and water management sectors to make informed decisions with confidence.
