Barrels per Hour (BPH) to Cubic Meters per Day (m³/day) Flow Unit Conversion Calculator
This tool converts Barrels per Hour (BPH) to Cubic Meters per Day (m³/day), hence allowing process engineers, oil & gas experts, and flow analysts to align U.S. petroleum industry units with worldwide metric standards.
Usually used in the oil and petroleum sector, Barrels per Hour (BPH) is a flow unit that indicates the amount of refined products or crude oil moved or processed each hour. Its foundation is the U.S. oil barrel, or 42 U.S. gallons.
  • Measuring the pace of crude oil production.
  • Pipeline refined product flow monitoring.
  • Tracking of petroleum output in refineries in real time.
  • Planning transportation for storage and tanker operations.
A metric measurement, cubic meters per day (m³/day) measures the volume of fluid moved or processed daily. Including water treatment, oil refining, and pipeline transport, it is commonly applied for large-scale industrial operations.
  • Municipal and industrial water supply control.
  • Daily oil and gas facility throughput analysis.
  • Reporting on compliance and regulations in metric areas.
  • Planning capacity for large-scale fluid systems.
Barrels per Hour (BPH) can be converted to Cubic Meters per Day (m³/day) by applying the formula:
Explanation: 1 barrel = 0.1589873 cubic meters, and there are 24 hours in a day,
so 1 BPH = 0.1589873 × 24 = 3.8156952 × 24 = 6.62478 m³/day.
If your pipeline flow rate is 100 BPH, convert it to m³/day:
100 × 6.62478 = 662.478 m³/day
So, a flow rate of 100 Barrels per Hour is equivalent to 662.478 Cubic Meters per Day.
Barrels per Hour (BPH)Cubic Meters per Day (m³/day)
1 BPH6.62478 m³/day
10 BPH66.2478 m³/day
50 BPH331.239 m³/day
100 BPH662.478 m³/day
250 BPH1,656.195 m³/day
500 BPH3,312.39 m³/day
1,000 BPH6,624.78 m³/day
  • Change oil production rates for reporting and international trade.
  • Match U.S. operational data to metric-based regulatory systems.
  • Allow uniform capacity planning over multi-regional sites.
  • Increase the accuracy of system modeling and forecasting in SI units.
  • Assist international cooperation on energy infrastructure initiatives.
For professionals in oil refining, petrochemicals, and fluid transport who require consistent unit translations between industry-specific and globally accepted standards, this conversion tool is ideal.
Visit our collection of 200+ Online Instrumentation Calculators designed for engineers, technicians, and automation professionals:  200+Online Instrumentation Calculators
