Bar to Psi Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from converting bar to pounds per square inch (psi):
A bar (symbol: bar) is a metric unit of pressure. It is equivalent to 100,000 pascals (Pa) and is commonly used to measure atmospheric pressure and pressure in various industrial applications.
Suppose you have a pressure of 3 bar.
  • To convert it to psi: 3 × 14.50377 = 43.51131 psi
  • So, 3 bar is equal to 43.51131 psi.
Here’s a quick reference table for common bar values to psi:
Bar (bar)Psi (pound-force per square inch)
0.1 bar1.450377 psi
0.5 bar7.251885 psi
1 bar14.50377 psi
2 bar29.00754 psi
3 bar43.51131 psi
5 bar72.51885 psi
10 bar145.0377 psi
20 bar290.0754 psi
50 bar725.1885 psi
100 bar1450.377 psi
  • Engineering Applications: Convert pressures in hydraulic systems, HVAC, and other engineering applications.
  • Instrumentation: For converting gauge readings from metric units to imperial units.
This calculator can be a handy tool for engineers, technicians, and anyone working in industries where pressure measurement is key. It’s especially useful when dealing with equipment that uses different units of measurement for pressure
