Advanced SIS Troubleshooting Quiz for Process Industries (25 MCQs with Answers)
This quiz is for experienced safety, instrumentation, and SIS engineers who fix safety instrumented functions in process plants. You will practice diagnostic interpretation, PFD reasoning, HFT evaluation, final element fault analysis, bypass methods, proof-test preparation, and IEC 61511 implications through twenty-five multiple-choice questions based on scenarios. There are questions that involve short calculations, realistic alerts, voting and logic-solver failures, communication problems, and partial stroke obstacles. Focus on troubleshooting procedures that can be taken, what to check first, potential causes, and ways to confirm them. Use this as a way to evaluate yourself and as a starting point for team debriefs or talks at work. It can also help you plan maintenance and testing better.
Are you ready to put your troubleshooting talents to the test on Safety Instrumented Systems? This difficult quiz tests the skills of experienced engineers by asking them to figure out what went wrong with real-world SIS systems and how to use diagnostics, voting logic, final elements, and proof-test approach. Expect issues that are based on real-life situations, short math problems, and procedures for detecting faults in real life. Focus on finding the fundamental causes, fixing the problems, and design flaws. Don’t just give simple definitions; do real troubleshooting with a focus on safety throughout the lifespan.
A runaway instrument generates spurious SIF activations via noisy sensor signal. Which combined mitigation is best?
During commissioning, you see frequent mismatches between field device configuration and SIS database causing alarms. What troubleshooting priority reduces risk fastest?
A proof-test finds a latent failure in a channel that diagnostics did not detect. What documentation and corrective steps are required?
A valve positioner shows oscillatory behavior causing spurious trips. What loop or device checks should you perform?
A safety instrumented function requires SIL 3 but installed architecture and diagnostics only justify SIL 2. Which practical troubleshooting/mitigation is correct short-term?
A breaker trip isolates a SIF final element power circuit; SIF did not alarm for loss of supply. Which safety design issue likely exists?
A distributed control network shows sporadic packet loss causing SIF interlocks to latch. Which mitigation is an immediate troubleshooting and design fix?
Calculation: A SIF uses 2oo3 voting with single-channel PFDavg = 2E-2. Approximate system PFDavg for 2oo3 architecture (failures must affect at least two channels) is roughly combination chance of two channels failing. Compute approximate order of magnitude.
You observe high diagnostic coverage reported by a transmitter (DC=90%) yet field failures still cause dangerous undetected modes. What’s the most practical issue to probe?
An SIF uses a pneumatic I/P and pilot valve; actuator fails slowly on demand during low temperature. Which real-world root cause is most likely?
A safety valve solenoid coil shows correct DC resistance but fails under operating voltage. Which test helps confirm intermittent coil insulation breakdown?
Calculation: A SIF final element actuator has a mean time to dangerous failure (MTTFd) of 200,000 hours. During proof-test interval of 2 years (17,520 hours), approximate contribution to PFDavg ≈ (TI)/(2×MTTFd). Using TI=17,520 hours, what is the actuator PFD contribution?
You detect divergent readings between two level transmitters in a 2oo3 voting SIF where the third agrees with channel A. What is the best immediate diagnostic reasoning?
An operator bypasses a SIF for maintenance but forgets to re-enable it; this is discovered 12 hours later. What root cause and remedy must be documented first?
A fieldbus-connected temperature transmitter intermittently drops out and SIF flags failed sensor. Which troubleshooting step most effectively isolates the issue?
Calculation: A SIF requires SIL 2 (PFDavg target between 1E-3 and 1E-2). Two identical channels in 1oo2 with independent PFDavg per channel = 5E-3, assume perfect voting and independence. What is approximate system PFDavg?
In a dual-channel transmitter where diagnostics report rising bias in one channel, what practical step reduces dangerous undetected failure risk immediately?
A SIF logic solver reports CPU checksum mismatch after firmware update; SIF stayed in bypass during update. What is the correct remediation?
Calculation: A 1oo2 sensor arrangement has HFT = 1. If one sensor fails dangerously, can the SIF still perform its safety function without spurious trip? Choose the correct statement.
The HMI shows an ESD SIF de-energize alarm but field valve shows closed command; valve remains open. What is the most probable fault to isolate?
A SIL 2 SIF uses a solenoid valve as the final element and experiences slow closing times. Which immediate troubleshooting action is most relevant?
Calculation: A single-channel SIF baseline PFDavg is 1.0E-2. Diagnostics detect 60% of dangerous failures. What is the residual PFDavg attributable to dangerous undetected failures?
A 1oo2 pressure sensor voting SIF shows frequent spurious trips when one sensor drifts slowly. Which change reduces spurious trips without reducing safety?
During SIF partial stroke test (PST) of a hydraulically actuated shutdown valve, the travel stops at 40% instead of 90%. What should you check next?
A pressure transmitter in a SIF intermittently reads 0 bar while process pressure is 5 bar; HART diagnostics show occasional high noise and an intermittent loop voltage dip. What is the most likely root cause to investigate first?
The average score is 74%
