Advanced Quiz on Intrinsic Safety Instrumentation Circuits in Oil & Gas Process Industries
In process sectors where explosive atmospheres are widespread, intrinsic safety (IS) is a very important idea. In oil, gas, and petrochemical plants, even the smallest spark or heat source can cause terrible tragedies. Intrinsic safety instrumentation circuits are made to keep electrical and thermal energy below ignition levels, which makes sure that operations are safe in dangerous locations. This quiz was carefully made for instrumentation and control engineers who have been working in the field for a while. You will be tested on IS barriers, field devices, grounding techniques, cable selection, IEC/ATEX standards, and troubleshooting methods through sophisticated, real-world scenarios. Today, put your knowledge to the test and improve your safety-critical skills.
Intrinsic Safety Instrumentation Circuits Quiz – Advanced Oil & Gas IEC/ATEX Knowledge Test
Intrinsic safety circuits keep oil and gas plants safe by stopping fires from starting in dangerous environments. This quiz tests your knowledge of IS barriers, grounding, cable selection, and IEC/ATEX compliance through difficult real-world situations. This course is for experienced engineers and helps you better understand intrinsic safety instrumentation in process industries.
Entity Parameter Compliance
A galvanic isolator has Uo=24 V, Io=100 mA, Po=0.75 W, Co=83 nF, Lo=4 mH (IIC). The field transmitter is Ui=30 V, Ii=120 mA, Pi=0.8 W, Ci=12 nF, Li=0.3 mH. The cable adds C=40 nF, L=1.5 mH. Is the loop compliant for IIC?
Upgrading Gas Group from IIB to IIC
A plant reclassifies a unit from IIB to IIC. What is the first re-assessment priority for existing IS loops?
Documentation for IS Compliance
Which documentation is most critical to prove IS loop compliance during audit?
Shield Termination in IS Loops
Best practice for cable shields in IS analog loops:
FNICO vs FISCO
FNICO is intended primarily for:
Power Budget & Voltage Drop
A loop-powered IS transmitter needs 12 V at 20 mA. Barrier drop 2.5 V, cable drop 1.5 V, controller needs 1 V compliance. Min supply?
Certification Marking Comprehension
Which marking is suitable for an IS transmitter for Zone 1, IIC?
Barrier Polarity & Return
Why must the return path of an IS loop be treated as part of the IS circuit?
Live-Work on IS Circuits
Which statement is true regarding maintenance in Zone 1 on IS circuits?
Inductance Margin Trap
Is it acceptable to ignore device inductance when the cable inductance is low?
Loop Calculation – Marginal Capacitance
Given Co(IIC)=90 nF, field Ci=20 nF, cable 45 nF, junction box device 5 nF. Compliance?
Mixed Trays Routing
When IS and non-IS cables must share a tray, which mitigation aligns with IEC 60079-14 practices?
“Um” Misconnection Risk
“Um” on IS apparatus denotes:
Entity Power Check
Barri­er: Po=1.2 W. Field device: Pi=1.0 W. Other parameters are OK. Compliance?
FISCO Spur Rule of Thumb
In a FISCO model for IIC, which is generally true?
HART over IS Loop
Main concern when enabling HART on an IS 4-20 mA loop?
Fault Tolerance by Protection Level
Ex ib circuits are designed to be safe under:
Cable Substitution
You swap a cable to one with higher capacitance per meter. Which must you re-verify first?
Barrier Earthing Integrity
For Zener barriers, the most critical installation criterion is:
Simple Apparatus Consideration
Which device is typically “simple apparatus” in IS?
Gas Grouping Impact
Moving from IIB to IIC classification primarily makes which entity parameter more restrictive?
Temperature Class Constraint
A sensor surface can reach 120 °C at worst case. Max gas auto-ignition concern is IEC T-class. The minimum acceptable T-class marking?
EPL & Zone Selection
A loop installed in Zone 0 must use equipment with which EPL / protection level?
Zener vs Galvanic in Brownfield Units
Which is the best reason to prefer a galvanic isolator over Zener barriers in a congested brownfield MCC?
Barrier Short-Circuit Behavior
A Zener barrier output is shorted to earth at field. What best describes fail-safe action?
The average score is 70%
Access 1000+ MCQs tailored for instrumentation engineers: Instrumentation and Process Control Quiz Hub – 1000+ MCQs for Engineers
