Advanced Control Valve Hunting Troubleshooting Quiz – Test Your Control Loop Expertise
The Importance of Control Valve Hunting One of the most annoying problems with loop stability in process automation is valve hunting. It makes things shake, makes it harder to regulate, and shortens the life of the valve. This exam lets engineers see how well they know how to find problems, tune loops, and diagnose positioners in pneumatic, digital, and electro-pneumatic systems.
This 25-question quiz is for experienced instrumentation and control engineers and covers real-world topics like:
  • Positioner tuning and feedback issues
  • Oversized valve selection
  • Process gain and dead time effects
  • PID loop optimization
  • Actuator and booster relay stability
This quiz will help you learn more about how to diagnose and fix hunting in complicated control loops.
Why Take This Quiz? This advanced troubleshooting quiz isn't just theory; it's based on real problems that refineries, power plants, and process industries often have to deal with. You'll find out how to: Find out what causes oscillations Use trend data to confirm stiction Differentiate mechanical faults from tuning errors Apply damping and filtering techniques to stabilize valves 1
Why Take This Quiz?
This advanced troubleshooting quiz isn’t just theory; it’s based on real problems that refineries, power plants, and process industries often have to deal with. You’ll find out how to:
When hunting persists despite perfect tuning and mechanical condition, what hidden factor is often overlooked?
A flow control loop exhibits hunting after installing a high-gain digital positioner. What’s the corrective action?
How does valve actuator size impact hunting tendency?
In digital control systems, what sampling issue can mimic valve hunting?
A valve hunts only during controller auto mode but not in manual. Which diagnostic step should be next?
Which of the following is most likely to cause hunting after maintenance?
What effect does actuator spring hysteresis have on control valve stability?
How can pneumatic signal filtering help in reducing hunting?
What is the effect of excessive derivative action in a PID controller on valve hunting?
Which valve characteristic minimizes hunting in flow control applications?
A control valve hunts only when process pressure fluctuates rapidly. What might mitigate the issue?
What is a common symptom of stick-slip behavior causing hunting?
A pneumatic valve with a booster relay exhibits rapid oscillation. What is the likely cause?
Which of the following can eliminate valve hunting due to process gain variation?
A process shows valve hunting only under low flow conditions. Which is most likely?
What effect does air line volume between I/P converter and actuator have on valve hunting?
A digital positioner shows a constant cycling output signal while the input from the controller is steady. What is likely wrong?
How does mechanical hysteresis contribute to hunting in a control valve loop?
A valve repeatedly overshoots its setpoint. The controller uses a fast integral action. What is the most probable issue?
The positioner’s nozzle-flapper system shows oscillating backpressure. What is the likely cause?
If valve hunting disappears when the positioner is placed in manual mode, what is implied?
Which control loop element typically introduces phase lag that worsens valve hunting?
A valve exhibits hunting only when operating near 40–50% travel. What is the most probable cause?
A control valve in a pressure control loop shows periodic oscillations even though the controller tuning is correct. Which component should be inspected first?
Which diagnostic test best confirms stiction as the root cause of hunting?
The average score is 56%
#ControlValveTroubleshooting
#InstrumentationQuiz
#ProcessControl
#ValveHunting
#LoopTuning
#AutomationForum
